Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-11-2004, 01:51 PM
Whale Whale is offline
High Idle Problem - V6
I've got a '93 Rodeo (V6/Manual trans) that has suddenly decided to go berzerk. When I come to stop (or let off of the throttle), the idle zooms up and down a few times before settling into an idle at around 2000 rpm. After a minute or so the idle will slowly drop down to a normal level.
Now here'e the crazy part... If I'm on an incline and move only a few feet (in neutral), the idle again races up to over 2000.
Obviously, something crazy is going on, but I can't seem to trace the problem.
HELP!!!
Old 03-11-2004, 03:04 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: High Idle Problem - V6
I think remember this.
There is a rubber boot thing on the throttle cable in the engine bay. Over time the rubber breaks down and causes it to stick.
I don't know where it is located at. You may want to do a search here to see what you find.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-11-2004, 09:09 PM
geg geg is offline
Thumbs up
A sticking throttle cable can do what you are experience. On my 1993 it was a combination of stuck cable and shot electric vacumn idle motor. The little motor is black and is located on the throttle body. It has two screws and a wire conector. Mine was about $40 at the local auto parts store. Works fine now with a lubed cable and a new idle motor.
Good Luck
