Electrical Problem?
Hi, I own a 89 camero, and I'm having some electrical problems with it.
The fuse, that goes inside for the automatic doorlock, and the horn of the car, its burn out. And every time I replace it with a new one, it will last for about 10 minutes, and it will burn out again. What can I do to fix this???? I will really appreciate any help I can get. Thanx |
Re: Electrical Problem?
you have a short in the system. somewhere the insulation on the wire has been rubbed off on a metal surface, and the power is going strait to ground. causing the short out. chase the wire, find the rub through, put foam tape on it, and then see if the fuse blows.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
Thanx for the info, I will sure try that, and let you what the result is. Thanx |
that's the exact same problem mine has, that's a lot of wire to look thru tho.
try disconnecting one power door lock switch. at a time if the fuse does not blow when one of the switches is disconnected then it is either a bad switch or you're short is on the wires to that switch. hope this helps.if the fuse still blows then try disconnecting the horn to see if the fuse still blows if it does not hook the horn up straight to the battery to see if it works. also make sure you are using the right size fuse
cig lighter is on the same fuse try to unplug it most likley you will find the problem there
dont suppose there is a penny jammed down in the bottom of the cig lighter is there????
ok i have almost the same prob but it is my dome and cig lighter fuse called lid but the wire runs to the back of the car and i dont know where to hook it up at i have tryed every thing but it burns out help!!!
