Old 03-11-2004, 11:46 AM
lawted lawted is offline
Question Service Engine Light
1997 Z71 350 engine. My SEL comes on after starting and sitting at an idle for about 30 seconds. It will also come on when the engine is warm during idle (again it will take about 30 seconds of idle). As soon as I put it in gear and go the light will then go out in all cases. The truck seems to run fine, no noticeable degradation in gas mileage or acceleration. This all started after I had an oil change done on the truck. It is not the gas cap as I have checked that. The air filter has been replaced. Any ideas?
Old 03-14-2004, 08:28 AM
Jeremy-WI Jeremy-WI is offline
Re: Service Engine Light
Have it scanned for codes, it could be a lot of things
Old 03-14-2004, 03:16 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
If you go to an Auto Zone or an O'Reilly's, you can 'rent' (no charge) a reader for OBD I or OBD II, I can't recall what your '97 has in it.
If you can pull a code from your truck, it will tell you what it is. You may not be able to get a code from it, unless it stays on though, but it's worth a try.
my
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 05-02-2004, 04:47 PM
Jeff7076 Jeff7076 is offline
Sounds like the O2 sensor.
Old 05-03-2004, 08:08 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Service Engine Light
Dude, never replace parts until you have done some diagnosis to determine the root cause of the problem.
If the SES light has come on, the PCM has stored a code that will aid in diagnosis.
Some of your chain auto parts stores have code readers and will scan the PCM for codes for free.
Next, get a manual and follow the trouble chart to determine the cause of the failure.
A little time spent diagnosing the complaint will save you a bunch of money and headaches.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
