Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 03-11-2004, 11:17 AM
diver2226 diver2226 is offline
Exclamation 2nd Gen won't keep running
My motor is definately not flooded.
When I go to start my car, it starts fine and then within 5 seconds shuts itself off. It won't maintain an idle at all. Even when I try to idle higher it kills itself. Any ideas?????
Old 03-11-2004, 11:29 AM
dayna240sx's Avatar
dayna240sx dayna240sx is offline
Banned
Send a message via AIM to dayna240sx
Re: 2nd Gen won't keep running
Check your BAC or TPS settings. Or check for vacuum leaks. Or you can also check to make sure your AFM is plugged in properly.
Old 03-16-2004, 03:06 AM
BDC196 BDC196 is offline
Send a message via ICQ to BDC196 Send a message via AIM to BDC196 Send a message via MSN to BDC196 Send a message via Yahoo to BDC196
The AFM is a good idea Dayna has posted. Also, make sure it's something simple like having an empty tank of fuel.
B
Brian D. Cain -/- Grand Prairie, TX -/- [email protected] [email protected]
BDC Motorsports - Performance Rx-7 12A/13B Rebuilds, EFI tuning, etc.
MSN [email protected], Yahoo! bdc196, AOL Symajhi, ICQ# 1733105
http://bdc.cyberosity.com -/- http://groups.yahoo.com/group/HaltechSupport
Old 03-16-2004, 04:31 AM
3rdWrldRcr 3rdWrldRcr is offline
Check your idle setting...If your idler is off it could cause it to drop too low on the rpms and shut the motor off. Another sign of this is if you have to keep reving at stops or redlights to keep it running.
Rabbit
Old 03-16-2004, 07:12 AM
Thanks guys. The gas level is fine. I don't think the idle adjust has anything to do with it because even if i put more gas on it after ignition it still kills itself.
I'm thinking more and more that it's probably a vac of some sort. Let you know what I come up with.
Old 03-30-2004, 09:31 AM
grobert50 grobert50 is offline
My 2nd gen won't run either
I recently bought a '91. It was idling rough only at start up but drove fine for several weeks. (The car had been sitting for a year when I bought it but cranked right up w/ a new battry )
I parked it one nite and the next a.m. the starter wld turn but the engine wld not crank at all. Sounded like no fire at all. I had it towed to the dealer and they say it needs a TPS and coolant sensor at about $1200!!! They say it is running now after they got it un-flooded but could stall and stop at any time now. My questions:
- Does this sound like the likely prob?
- Can I change these sensors myself? (I have changed both on Ford and Chev eng's before and I have the rx7 Haynes manual already)
- Is this common on 13b rotaries?
