Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-11-2004, 06:26 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
still overheating Help!
hello all I got a 92 ka24de engine. I have just replaced all gaskets including the head gasket,also replaced radiator and im still over heating under hard driving temp shows almost to the first bold bar but i dont hear the radiator boiling any sugetions?
Old 03-11-2004, 12:59 PM
stealthj's Avatar
stealthj stealthj is offline
Send a message via AIM to stealthj
Re: still overheating Help!
thermostat
remove it and drive without it see what happens
BANNED
Old 03-11-2004, 01:51 PM
mrflip69 mrflip69 is offline
Or air in your system... try bleeding
Old 03-11-2004, 04:09 PM
brand new thermostat and already blead system with bleeder screw and all!
Old 03-11-2004, 04:48 PM
Try bleeding on an incline. Who knows, your gauge might be messed up too? How hard are you driving... might be normal
Old 03-11-2004, 10:11 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
hard driving on twisty roads where you don't really get up to speed or what? Maybe you need some better fans.
Old 03-12-2004, 05:16 AM
ya im running on the stock electric fan with the belt driven fan removed. i am getting over heating at going a excess of over 110 so i figured this may be a little dermatic. also the heater has issues with getting hot it will only get hot at high revs. this may be relating to the same issue.
thanks All!
Old 03-12-2004, 09:13 PM
Chuki_breath Chuki_breath is offline
ur engine overheats but ur heater doesnt work???? hmmm usually ur hot air is extremely hot when over heating? thats just odd?
Old 03-13-2004, 09:16 AM
ettinnov03 ettinnov03 is offline
Send a message via AIM to ettinnov03
I had a problem with my KA24E overheating, replaced everything anybody ever thought of doing. The car would get real hot in about 15 minutes of driving. You could pop the hood and my coolant would be boiling inside the resvoir. Pop the top to the radiator and no coolant was moving. Check the termostat, it wasn't that. Turns out it was my head gasket. I used one of those felt-pro head gaskets(official gasket of Nascar). The gasket wasn't cut out right for the head. I bought the whole rebuild kit funny that was the only thing that didn't fit right. Hope that helps somewhat.
Old 03-17-2004, 08:56 AM
i replaced the head gasket actualy every gasket to the head! i was thinking maby water pump going bad or somthing? im not loosing water when the system is cool i pop off the radiator cap and the system is toped off with no oil in it or anything resivor also stays full.....
Old 03-17-2004, 08:57 AM
will the heater work without the thermostat.. also what is the draw back of running without a thermostat.. i do live in a hot area desert!
Old 03-17-2004, 09:27 AM
musicsurfman musicsurfman is offline
Send a message via AIM to musicsurfman Send a message via MSN to musicsurfman
I Can Tell You Your Problem Right Now.....
You Just Took 850cfm Out Of Your Radiator And Direct Air On The Engine And Didn't Replace It With Anything.
That Dinky A/c Fan Is An Auxillary Fan To Aid In The Cooling Of The Engine With The Added Stress Of The A/c System. You Need To Either Hook Up The Clutch Fan Again Or Get A Electric Fan To Replace It. You Need To At Least Have The Clutch Fan Hooked Up To Pull The Air Through The Radiator And Blow Cooler Air Directly On The Engine.
If Your Car Is Over Heating Under Hard Driving Still After You Fix This Problem Try A Higher Temp Thermostat.... The Reason You Go To A Higher Temp Is To Slow The Flow Of Water Through The Radiator To Allow More Time For The Water To Transfer Heat Out And Cool Off Again.
Old 03-17-2004, 09:29 PM
good stuff i knew i shouldnt leave the thermostat out... i also knew that the fan needed a to be replaced with a bigger electric fan.
i must be high
thanks
peace!
Old 03-18-2004, 09:14 AM
good luck.... Heating issues suck I know because I'm having them.
Old 03-18-2004, 02:48 PM
u running turbo?
