Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-10-2004, 10:20 PM
badassaccordriver's Avatar
badassaccordriver badassaccordriver is offline
Send a message via AIM to badassaccordriver
bye bye accord....
getting rid of my accord, i was thinking of buying a 89 or 90 CRX. the first thing i would probably do is a swap, but i don't know much about CRX swaps. its going to be a daily drive and i plan to go n/a, any swap ideas?(plus how much work is involved in each swap) i've just been looking at the h22 forever, so i don't know much about the other motors. bye bye accord.....
Old 03-11-2004, 12:16 AM
i've been looking at quite a few engine sites, and i think i'm going with the B16A. if its going in either a 90 or 91 CRX HF, will i need the "complete changeover" http://www.hmotorsonline.com/shop/sc...age&item=30005, or can i just get by with this http://www.hmotorsonline.com/shop/sc...age&item=30004? will i need new mounts for the b16 swap? can i use the existing tranny on the CRX? help out a CRX noob....
Old 03-11-2004, 08:08 AM
defman's Avatar
defman defman is offline
If you have your mind set on the b16a, which would probably be the easiest swap. then make sure that you buy a 1st gen b16a from a respectable company. To save time and possible money i would buy a complete swap. The reason you should buy a 1st gen motor is to keep from having a wiring nightmare and so you wont have to worry about how to get that hydralic tranny to work. I bought my JDM B16A from inlinefour.com they sent me a really clean motor, although they do cost a little more.
Old 03-11-2004, 08:13 AM
SRV BOY SRV BOY is offline
Re: bye bye accord....
The H22a comes with 205hp if u get it from japan
Old 03-11-2004, 08:22 AM
Re: Re: bye bye accord....
uhh.....thats nice.....
Old 03-11-2004, 08:28 AM
http://www.totaljdm.com/index.cfm/fu...1/B16A_jdm.htm
would you consider that a complete swap? i've also heard that you'll need a Throttle Cable Bracket, Front Steering Knuckles from a CRX Si, and 90-93 Integra Axles, is that all true?
Old 03-11-2004, 08:39 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
if you have an HF your gonna need those front suspension parts. if you want an extremely easy swap go with any d-series swap or a ZC. you wont need new mounts or wiring harnesses. as for the b16, its a better base to start with, you'll need the full changeover though, as it comes with the ecu, axels, and wire harness.
any b-series will be just about the same, only differences would be to wiring. H22 is not an easy swap at all, alot of modification needs to be done in order for that motor to drop.
i got my b16 from www.hmotorsonline.com and any tech info for the swap is available at www.hasport.com
hope this helps.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-11-2004, 08:46 AM
Re: Re: Re: bye bye accord....
uhh .. just letting you know, u mention it earlier ....
Old 03-11-2004, 03:02 PM
Re: Re: Re: Re: bye bye accord....
sorry if i came off sounding like a dick, i was going to get an h22 for my accord, but i'm going to go ahead and take the crx path.
Old 03-12-2004, 07:51 AM
Ur gonna take the crx path!! why man ??
Old 03-12-2004, 07:53 AM
Its cool, i didnt mean to sound defensive, its just that there are so many dicks on this forum, i just thought u were another one of em
Old 03-12-2004, 08:22 AM
i was going to buy a crx in the first place, but the accord kind of fell in my lap........1800 lbs sounds pretty good after having a 3000+ lb accord
Old 03-12-2004, 01:47 PM
oh, i understand, well if u ever decide to take the prelude path, u wont be sorry. You will be damn happy
