Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-10-2004, 09:19 PM
98-ls 98-ls is offline
cams and valvetrain
i want to get some cams, im thinking stage 2 crower. im going to get some other things for my car (integra LS) i dont really have money to get it all and up grade my valvetrain. i do beat on my engine alot. do i really need to get springs and retainers.
Old 03-11-2004, 12:05 AM
SenseiAccord SenseiAccord is offline
Re: cams and valvetrain
you may want to change the springs and retainers is u want ur RPMs to redline at 10,000. Otherwise if u leave it stock then the stock redline is most recommended. If u were to rev ur engine to 10,000 on stock springs and retainers then ur valves will just be floating cuz it is moving so fast that the springs wont even have time to react. Know what i mean? If im not mistaken... if u get a stage2 cam... they recommend to swap out ur stock springs and retainers. I know stage one u can leave in ur stock ones. Nah get some springs and retainers tho.... its worth it. Seeing ur Tach bounce and reving to 10,000 and still making power is something u gotta see. Good luck buddy!
Old 03-11-2004, 08:47 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yes you do need to get new springs and retainers, as he said the motor wont be able to handle the higher lift and duration of the new cams, eventually the stockers will break and cause alot of damage.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-11-2004, 08:12 PM
defman's Avatar
defman defman is offline
dont forget you would have to get your ecu chipped to rev to 10 grand
Old 03-11-2004, 10:29 PM
if red line is the same do i still need to upgrade the valvetrain.
Old 03-12-2004, 09:44 AM
crxlvr's Avatar
as a precaution i would especially if you are going with stage 2's.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-12-2004, 09:42 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
You might want to consider getting just the springs. The titanium retainers that come with the kit are a wear item, they wear rather quickly IMO you have to check them at around 10K and keep a close eye on them. I have heard of people having to replace them after around 15K. The stock retainers will hold up, the titanium are just lighter basically.
Old 03-12-2004, 10:45 PM
that helps a little on price
Old 03-13-2004, 05:19 PM
one more question. after installing springs and cams, how do i adjust the valves, is it the same gap as stock cams?
Old 03-13-2004, 05:36 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Yes same gap. And you absolutely, positively, 100% want to upgrade you valve train with ANY stage 2 cam.
Old 03-13-2004, 09:00 PM
last question on this i promise. stage 2 cams are called street/strip, so how reliable are they for long trips, like 500 miles?
Old 03-13-2004, 09:08 PM
whtteg's Avatar
You are talking about the 62403's right? If so then they will be fine on a long trip. I know some guys around here that have them and they have had no issues with them. You will need to get the motor tuned after you install them though, or it will run kinda rough, and run rich at idle.
