Old 03-10-2004, 07:15 PM
z34dohc z34dohc is offline
Unhappy Capasitors Charging
I just purchased a cap for my system. And i was wondering if anyone has the CORRECT way to pre charge them. Also I am wondering if i run extra lights( for under the car and interior) If it is a good idea to get another cap for this? Or another battery? The alt is already at it's max for output, I believe it is up around 140+, I have no dimming problems!
Any help on this would be great.
Thank you
Peter
Old 03-10-2004, 07:20 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Capasitors Charging
if you have no dimming problems then why did you get a cap? You bought a bandaid when you don't even have a cut.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-10-2004, 07:25 PM
ok, I have a bandaid...lol... k if i was going to install it how do I pre charge it. I know there is a way and i want to make sure it is done right.
Thank you
Peter
Old 03-11-2004, 10:28 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
to charge it have the negative side already hooked up - then attach a 1k ohm resistor to end of the power wire and touch the other end of the resistor to the positive cap post for a few seconds. Then you can attach the power to it without it arcing.
Old 04-03-2004, 11:43 PM
thanks for the info....I tried the cap and the manufacturer an have the thing back.....i need to upgrade the alt, wiring and battery... caps are useless in this application.. not against them just NO THANKS..Hey thanks guys for all the info...
Peter
Old 04-04-2004, 10:20 PM
Audio Guy
they only help sometimes ... if it has a digital voltmeter, it's worthless
