Old 03-10-2004, 05:09 PM
EclipseGrly99 EclipseGrly99 is offline
Send a message via AIM to EclipseGrly99
New Here, need some advice on a few Mods.
i have a 99 rs and i want to make it run faster. wheres the best place to start? i was thinking an air intake....whats a good one?
thanks
Old 03-10-2004, 05:17 PM
dpd96gst dpd96gst is offline
Re: New Here, need some advice on a few Mods.
I just bought a k&n cold air intake from advanced auto parts for about 124$ i have heard they are ok but i don't hve time till this weekend to put it on. if you decide to get that one make sure it is the FIPK(Fuel Injection Performance Kit) other than that i am pretty new here also so i don't really know what i can mod easily other than that.
Old 03-10-2004, 05:22 PM
thanks a lot...tell me how it is when you install it.
Old 03-10-2004, 05:24 PM
i will also you should watch your milagecuz the timing belts need to be changed around every 60000 to 70000 miles i learned the hard way so good luck and i will let you know sat or sunday.
Old 03-10-2004, 05:26 PM
yeah ill def watch that...it only has about 40,000 right now but thank you
Old 03-10-2004, 05:43 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
intake exhaust headers is about all you can do without a lot of cash, before turbo.
Old 03-10-2004, 05:44 PM
where would i get something like that?
Old 03-10-2004, 05:52 PM
if i do all that about how much faster will that make it?
Old 03-10-2004, 08:27 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: New Here, need some advice on a few Mods.
you can look around ebay for some cheaper ones... also a hi-flow cat sohould be on the list
Old 03-11-2004, 12:27 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
what happens if you dont change the timing belts?
Old 03-11-2004, 01:27 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Lets see....If you don't replace your timing belt ........BOOM!!! Sooner or later the timing belt will break. When that happens there is a very good chance that the pistons will contact the valves...VERY BAD and VERY EXPENSIVE. It is recommended that when you replace the timing belt you also do the balancer belt, tensioner, and water pump. These are all cheap parts but the labor to get to them (if you aren't doing the work yourself) is very expensive.
Old 03-12-2004, 02:07 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
ok i just put a intake on mine here is a good one
http://www.streetstyler.com/JKLColdAirIntakes.htm
Old 03-12-2004, 05:58 PM
goalieman24's Avatar
goalieman24 goalieman24 is offline
Send a message via AIM to goalieman24
ebay is your friend
soon to be stage 2
