Been having trouble with the electric windows in my van for almost 2 years now. Will go down partway, then not back up, will stay down then eventually go up if your lucky over the next 1/2 hour.
Well I am going to attempt to fix this problem should I start with the switches? $90 for them all at the dealer, and salvage yards around don't have any. Suggestions?? |
Re: Electric Window Switches 96 LT Astro
Had similar problem, I replaced drivers side window lift motor, my passenger side still bad it needs help going up. Will replace motor soon. Web price for motor is $60. I believe this is a common problem.
Thanks Sonnald, I ordered new switches first as this is the easiest thing to replace. If that does not solve the problem I will move onto the motors. The reason I believe it is a switch is that when the windows do work they go up and down unassisted. It does not seem like the motors are "weak".
Thanks for you input. |
Thanks for the input..
Well, I was inpatient and ordered the switches prior to your reply pringlemr.
I appriciate the input and if the switches do not work I will go on to the motors. Was Autozone the best $ you found for the motors? I have had really good luck with www.gmpartsdirect.com when it comes to finding stuff. |
Re: Re: Electric Window Switches 96 LT Astro
I recieved the switches that I discussed above and you were correct. The windows still don't work correctly, will have to invest in motors next. How hard is the motors to change? |
