Old 03-10-2004, 02:33 PM
l2ice rocketz l2ice rocketz is offline
Send a message via AIM to l2ice rocketz
How does the Rotor manage to fall off?
I was driving one day, and my rotor screw somehow popped off inside the dizzy, and the rotor fell off. I thought I messed up my engine for a couple of minutes. I put it back in though. How does this happen? I was pretty sure that I tightened it well-enough last time (even used a small ratchet to tighten it. Can you prevent this?
91' Civic LX 4G4D
May 1, 2004 9:20 PM
R.I.P.
Old 03-10-2004, 02:45 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: How does the Rotor manage to fall off?
loctite.
SOLD!
Old 03-10-2004, 02:47 PM
1995 geo tracker's Avatar
1995 geo tracker 1995 geo tracker is offline
put a little drop of blue lock-tight on the bolt , that should help
Old 03-10-2004, 03:14 PM
Mtrujillo's Avatar
Mtrujillo Mtrujillo is offline
Send a message via AIM to Mtrujillo Send a message via MSN to Mtrujillo
Yeah a little Loctite should be able to keep that bolt in place, that's wierd though this is the first time that I have heard of a rotor bolt falling off. Crazy, well at least you didnt damage your engine.
Old 03-10-2004, 03:30 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
happened to me twice, on two seperate cars. loctite fixes that
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-10-2004, 03:34 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Dang. This happened to me every day for a week. I'd try to climb this massive hill, and about half way up, the screw would come out and I'd be by the road side wearing a suit playing with my dizzy.
I finally replaced the rotor and the screw and got it on there really tight...and then the whole distributor quit on me.
Shoulda got loctite.
Flunky
PS-The fun part was having a dead motor and needing to rotate the distributor to get it to just the right spot. I'd put the car in gear and let it roll backwards for a foot.
Old 03-10-2004, 04:27 PM
I've heard that you can put in your rotor wrong? Does it really make a difference? Something about 180 degrees off or something?
91' Civic LX 4G4D
May 1, 2004 9:20 PM
R.I.P.
Old 03-10-2004, 05:06 PM
lilol89crx lilol89crx is offline
ive had this happen once. i had no loctite on hand and ended up using silicon sealer. works like a charm and is still kickin 10k miles later
Old 03-10-2004, 05:15 PM
Do you just apply loctite after you've screwed in the screw tightly?
91' Civic LX 4G4D
May 1, 2004 9:20 PM
R.I.P.
Old 03-10-2004, 05:32 PM
GTA's Avatar
GTA GTA is offline
Whee..
no you put it on the threads of the screw before you put it in.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 03-10-2004, 06:50 PM
So does it matter at all where the screw is when you take off the dizzy? I've heard that you can install the rotor 180 degrees off or something?
91' Civic LX 4G4D
May 1, 2004 9:20 PM
R.I.P.
Old 03-10-2004, 06:58 PM
GTA's Avatar
GTA GTA is offline
Whee..
not on our cars, the rotor should be shaped on the inside kinda like a D so it only fits on the dizzy the same way.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 03-10-2004, 09:33 PM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
I could be wrong but I'm hearin a common theme...Loctite...
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 03-10-2004, 09:50 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Old 03-10-2004, 09:54 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Josh you are a true smartass...you're learning well from me, lol.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
