Old 03-10-2004, 01:30 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Greddy Full Auto Turbo Timer
I bought a greddy full auto turbo timer, but the manual came in japanes or something similar, I understand that I have to plug the harness behind the key, but also have to instala 1 cable to the speed sensor on the computer, I don't have idea of where is the computer and wich cable I have to cut and join.
Thanks in advance.
P.S. I bought the harnes for my tsi awd so I guess that this will be a plug & play.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 03-11-2004, 12:34 AM
Question Re: Greddy Full Auto Turbo Timer
I put the turbo timer today and looks great, but... I thought that the idea of a turbo timer was to keep the motor running with the key out. But when I finish with the instalation and I tried to test if it works like that I notice that if i take out the key the car turns off, if anyone have an idea of what could be wrong... cause I have no idea. check everythin and all the connections are right I bouth the harness so it's soppouse to be a plug and play.
It's pretty deficult tu find the SPEED SENSOR CABLE but i find it and works great.
If anybody have a better idea i will cut the harness (12v cable) & i will conect it directly to the batery.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 03-11-2004, 12:38 AM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
http://www.scuderiaciriani.com/rx7/G...er_manual.html if you hooked up the parking brake feature make sure the baking brake is on, if not the car will kill.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 03-11-2004, 12:41 AM
May you explain that a little bit please.
Thanks
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 03-11-2004, 12:46 AM
read that link i sent you, it says something about a barking brake feature that will kill the car if you dnt put the brake on b/4 you try to take the key out.
Im getting my turbo timer in a couple days so if you havnt got it by then i'll take pics and post a step by step for you.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 03-11-2004, 12:55 AM
I did everithin like said in the manual, but i'm not sure may be I don't understand something when they explain to me how it works.
I thought that the turbo timer keeps the car runnin until the turbo goes down (turbo rpm) with the key out, like: "i get home, park the car take out the key and the car still runnin until is cold"
Thats what I understand, may be i'm wrong.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 03-11-2004, 12:58 AM
you have to set it to a certin time.that link i sent says how to set the time and some other things.Read it carefully and make sure you did it right.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 03-11-2004, 12:59 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
The turbo spinning or engine getting cold has nothing to do with a turbo timer. The point of running a car after hard runs is to cycle the oil through the turbo lines so that it doesn't foul them up.
The turbo spins because of exhaust gasses. At idle, it will spin the same rate.. and won't slow down no matter how long it idles.
The 'engine' is a constant temperature while running unless it isn't to operating temperature yet. Idling the car doesn't cool down anything except the coolant.
Old 03-11-2004, 01:05 AM
Thanks JoeWagon i already know that but I couldn't explain my self like that cause my english is not that well, but thanks anyways.
And I already did all the setups the that moder f****r still not working like i'll like to. It's like if when I took out the key I leave the turbo timer without energy. Sorry about my explanations but like I said before my english is not good enough
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 03-11-2004, 01:10 AM
JoeWagon's Avatar
Banned
I know nothing about turbo timer wiring but here goes:
Your key (ignition) is cutting off power to the turbo timer. You need to give the turbo timer power even when the key is off... so hook it up to a constant 12v power source, instead of a switched source.
Old 03-11-2004, 01:11 AM
so when you take the key out the turbo timer shuts off, that means you have the constant power hooked up wrong.You have to hook it to a 12v constant. Run it straight to the battery
Old 03-11-2004, 01:12 AM
Oh yea how much did you pay for your Turbo Timer
Old 03-11-2004, 01:13 AM
Talking Re: Greddy Full Auto Turbo Timer
Yeah somebody understan what I said before when I said "i'm going to put it directly to the batery . It's easyer like that
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 03-11-2004, 01:15 AM
lol u didnt say it would shut all the power off to the turbo timer you just said the car would kill.
Old 03-11-2004, 01:16 AM
95ClipseGS-T Thanks for your help, I'll like to see some pics of your car when you install the turbo timer, please.
Thanks to you too (JoeWagon)
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
