Old 03-10-2004, 12:41 PM
karkarbinks1 karkarbinks1 is offline
blower control module
The fan on my '97 GP recently stopped working correctly. It only blows air out when on setting 5. (the highest setting) I've been told that this is a malfunctioning blower control module. Do you guys agree with this diagnosis? Thanks!!
Old 03-10-2004, 01:39 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: blower control module
It could be the resistor. In my car it failed and the blower only worked on level 3 up to 5. It was the blower motor resistor and is located behind the radio on the evapoarator enclosure really high. It is a pain to get it out, but usually that is what it fails not the switch and is inexpensive ~20 bucks.
Old 03-11-2004, 04:34 AM
rockford0384's Avatar
rockford0384 rockford0384 is offline
kilroypr is right its the resistor if it only works on 5 its mostlikely the resistor Same problem I have had once before... when it was in dead winter and then it would work then not it sucked... but anyways its under the dash on the passanger side way up there "pain in the ass" to get to any info need just respond back hope that helps... the part costs only 20 dollars (that is what i got mine for)
1996 Ranger with 249,xxx miles on it...
was my beater now my daily driver,
still trying to figure out how that happened
99 MXZx 440 SNO PRO
Forsale
89' Honda TRX 250R
Old 03-11-2004, 06:45 AM
michelq michelq is offline
I would check the ignition switch
Old 03-11-2004, 03:30 PM
kilroypr's Avatar
michelg, why would you check the ignition switch?
Old 03-11-2004, 07:04 PM
yeah why would you check the ignition switch...
99 MXZx 440 SNO PRO
Forsale
89' Honda TRX 250R
Old 03-12-2004, 04:24 AM
ok if you check the wiring diagram you will see what i am talking about
Old 03-12-2004, 10:27 AM
If it is indeed a "pain in the ass" to get to, how much is it going to cost me in labor to get that $20 part replaced?
Old 03-12-2004, 01:36 PM
The Ladies Man's Avatar
The Ladies Man The Ladies Man is offline
Send a message via AIM to The Ladies Man
This is ROCKFORD0384 on my buddy account Its not really A big pain in the ass, it just takes a little time to get it out, because you have to reach all the way up to the dash basically from under the dash to undo 3 screws which 2 of them come out really easy compared to the 3rd that has like a rubber piece that is in the way of making it easy to get out. (unlossen it a little though so you can move the resistor a little bit to get it out) you should see it if you look up there
2000 GMC Sierra Z71
Mass Air Flow Sensor
Arraid TB Spacer
Flex-a-lite electric fans
160 degree stat
Edelbrock headers
HPP3
Dual Flowmaster Exhaust Series 40
K&N FIPK
Old 03-12-2004, 09:28 PM
kilroypr's Avatar
I have not checked it recently but to my humble understanding there is no relationship between the ignition switch and the A/C blower motor control. It is a simple circuit with a fuse on it. The resistor has 6 prongs, a common for all setting and the other have varying OHM's depending on the fan speed. The higher the fan speed the less the OHM being used on the resistor. It is not simpler than that. If you know somthing for sure, please, share it with us. I love to learn
Old 03-13-2004, 10:31 AM
Understanding the relationship between the Ignition switch and the blower control. The ignition switch feeds the blower control through a fuse in the fuse box and consequently when the ignition switch goes bad, it will not have enough power to supply the fan through the blower resistor; But, it has enough power to kick in the blower high speed relay.
Thanks
Michel
Old 03-15-2004, 08:37 PM
73superduty's Avatar
73superduty 73superduty is offline
Lost in plastic
I'm going through the same thing. I park my GTp through most of the winter. Only getting it out if need be. My problem is, no fan at all. I was told the same thing you guys mention. It'll be getting worked on this spring, in the warmth. LOL
Thanks for the tips though guys!
Chris
Old 03-15-2004, 09:55 PM
it take like 20 minutes to replace man do it when you get a chance seriously why park it when its not that bad of a job
99 MXZx 440 SNO PRO
Forsale
89' Honda TRX 250R
