Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-10-2004, 08:15 AM
Homer J Homer J is offline
Coolant or ATF leaks
I have a 2001 Eclipse GT Spyder. Anyone with a 2001 V6 have any problems with ATF or coolant leaks. I haven't seen any puddles on the ground under the car but I constantly smell it when I get out of the car after driving it for a few minutes. Plus in the summer I smell it from inside the car while sitting in traffic with the top down. I can't figure out what kind of fluid and niether the cooling or ATf fluids seem to drop. I did read a recall about a ATF cooling line needing to be replace on the 2001's.
Any help would be greatly appreciated.
Thanks,
Doh!
Old 03-10-2004, 08:53 PM
SkiNutJones SkiNutJones is offline
Send a message via AIM to SkiNutJones
Re: Coolant or ATF leaks
man I have an "01 GT and if I run it hard or for a distance I get the same smell. No leakage, but it smells like antifreeze. I dont know what it is.
Old 03-11-2004, 07:54 AM
Re: Re: Coolant or ATF leaks
Do you have a Automatic?
I found this on http://www.nhtsa.dot.gov/.
Make: MITSUBISHI
Model: ECLIPSE SPYDER
Year: 2001
Recall Number: 01V011001
Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSIONS. A HOSE WAS MIS-MANUFACTURED AND COULD WEAKEN OVER TIME, WHICH COULD RESULT IN LEAKAGE OF THE AUTOMATIC TRANSMISSION FLUID.
By the way this is a great site for finding recalls and issues that others are having with their cars.
Old 03-11-2004, 04:01 PM
No I have a stick. Thanks though.
Old 03-13-2004, 10:31 AM
Rulez Rulez is offline
Send a message via AIM to Rulez
Have you checked the fluid levels to see if they have dropped?
Mike Rule
2000 Mitsubishi Eclipse GT Turbo
www.club3gfl.com
www.fiautosports.com
