Old 03-10-2004, 04:06 AM
lly1982 lly1982 is offline
advise needed
i've got a ef9 civic, i have added full s/s exhaust de-cat and a free flow filter, just want some advise on what i should do next speed wise. was thinking about adding apexi safc 2 but is there any point? or uprated fuel pump? just need some sensible ideas.
Old 03-10-2004, 10:17 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
What motor do you have? If it's the 1.6l, you got lots of options, if it's the 1.5l, you don't. If I had the 1.5l I'd be looking at a swap. Do you have any other mods besides the exhaust and intake. Honestly, I would do a header next - it'd give you more HP than a SAFC or anything fuel wise at this point.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 03-10-2004, 10:24 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
More then anything it's what you have planned for the long run, along with what kind of driving conditions your in.
There is really not much you can do, after all the bolt-ons have been added. Unless your thinking about doing a swap of some kind or FI, cam(s).
Most cases going with a bigger fuel pump will create more headaches/issues then it's worth. Honda has pretty much squizzed all the performance your going to get already. Unlike what we have with USDM crap, and all the extra hp gained by aftermarket this or that.
Sooo, it comes back to what do you have planned/type of driving...?
Just some thoughts...
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 03-10-2004, 03:23 PM
Re: advise needed
i've got the jdm sir b16a engine, i read somewhere that you can swap some of the type r parts over to the b16a, what parts would really be worth swapping over? i just intend to use the car for daily driving but need it to be faster on the lower end, well am from the uk so u can guess what kind of weather is over here.
Old 03-10-2004, 03:54 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: advise needed
you have a b16a? then get some civic type R cams, either the type R or the skunk2 intake manifold (they are essentially the same). if you dont have a header yet, get one that is similar to the 4-1 style like the type R. if you feel like jumping into the engine a little, Civic type R pistons will give you higher compression.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-10-2004, 03:56 PM
Mtrujillo's Avatar
Mtrujillo Mtrujillo is offline
Send a message via AIM to Mtrujillo Send a message via MSN to Mtrujillo
Re: advise needed
Dude you can swap every part from the B16A engine into yours...I have the Type R Cams, Type Header and the Type R Intake Manifold on my baby, and it rocks !!!!!!!!!!
Old 03-11-2004, 01:03 AM
Hybrid1990crx's Avatar
Re: advise needed
and i'd also get vafc instead of safc.
Old 03-11-2004, 04:15 AM
Re: advise needed
which parts will be a straight over swap? how bout valves, spring, retainers?
Old 03-11-2004, 11:43 AM
Re: advise needed
Almost any b series part will swap right over. And yes, vavles and springs and retainers can all be taken from a type R and put into your b16 head.
