Old 03-09-2004, 06:22 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Is there a difference between Si and ZC Intake Manifold?
I have an Si engine in my car (EX 4Dr) it came stock. Would I notice any difference if I put a ZC Intake Manifold on it car????
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 03-09-2004, 06:30 PM
Mtrujillo's Avatar
Mtrujillo Mtrujillo is offline
Send a message via AIM to Mtrujillo Send a message via MSN to Mtrujillo
Re: Is there a difference between Si and ZC Intake Manifold?
I think you might considering that it is desinged for DOHC engines so I'm asuming that it should provide some more airfloe to your engine. But I may be wrong!
Old 03-09-2004, 06:43 PM
Hybrid1990crx's Avatar
Unless hes talking about the SOHC zc. Im not even sure if the DOHC will mount without some mods, i think the holes may be alittle off, but you can get it to work with if you widen them, I think. The sohc im not too sure. it will probably work. And if it does give a gain, it probably wont be much...
Old 03-09-2004, 06:49 PM
Mtrujillo's Avatar
Well see that's what I was thinking...I dont think that it will fit! I really dont think it will fit 4G! But if you can prove us wrong more power to you bro!
Old 03-09-2004, 07:43 PM
4G4D Store's Avatar
Well, I've got the SOHC ZC (D16A6) Engine in my car right now, I was just wondering if I put the DOHC Intake Manifold (if it will fit up to the D16A6) if I would get more horse, or if it'll be a waste. Has anybody even done this?
Old 03-09-2004, 07:55 PM
Mtrujillo's Avatar
Well if you get it to fit, I think there will be in increase in power it may not be alot but I think there will be considering the desing in the manifold. The DOHC manifold will provide more airflow than a SOHC manifold will, I'm pretty sure the chamber size is defferent so you'll get more air, not to mention if you use a ZC or aftermaket throttle body weith it.
Old 03-09-2004, 11:31 PM
lilol89crx lilol89crx is offline
only way to make it fit is to cut and weld on a sohc base plate. the zc base plate is wider and the bolt holes are aligned differently. the coolant passages on both mani's are slightly off from each other. some one had done this to an ls mani. dunno the actual results of this but it looked like crap.
Old 03-10-2004, 04:12 PM
Mtrujillo's Avatar
yeah dude I wouldnt even bother to do that swap..
Old 03-11-2004, 11:10 AM
4G4D Store's Avatar
I think your right - just I thought I had. I'm thinking instead of putting a 92-95 head on my engine and running a mini me, or just save up for the turbo. he he
