Old 03-09-2004, 04:01 PM
Hybrid1990crx's Avatar
Speedo cable
Ok so my speedo has been broken since I got my car. I checked the conection into the tranny and the connection behind the cluster, both were in. I removed the cable from the back of the cluster and took it for a spin. I'm not sure, but if the cable was working ok, I would see the little tab inside moving, right? Well I didn't see it moving. Does this just sound like a broken cable? And do I have to go to the dealer to get a new one?
Old 03-09-2004, 04:04 PM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
Re: Speedo cable
not sure if it is broken but if worst comes to worst, go to the wrecker
Old 03-09-2004, 07:17 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Speedo cable
maybe the cluster needle is broke
Old 03-09-2004, 10:42 PM
Re: Speedo cable
i dunno if its the cluster. the needle thing on the inside of the speedo cable doesnt move at all. so im thinking its the cable?
Old 03-10-2004, 12:24 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Speedo cable
if you took your cluster off and drove, but the wire still didnt move, then either your cable is broken or the speedo sensor is broken
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-10-2004, 01:18 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
I had this same problem last summer, and I know this isnt going to help at all, but all I did was unplug it and re-plug it in like 10 times, and blew in the hole, and wiped off the end of the cable. I feel like such a retard now, doing those things, but you know, it worked. I dont know why, but for some reason, I plugged it in that last time, and it worked right there. It was so funny...
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
