Turbo Port
I was wondering what type of port would be good for a turbo II. Is bridge port too much for stock turbo? i'm not sure if the intake needs any kind of restriction or not, that's just things i've heard. thanks for the help.
Re: Turbo Port
The best would be a street port. There is no point to a bridgeport because your turbo wont be able to keep up.
Re: Turbo Port
yea street port will give you pretty decent power anyways, and doesn't sacrifice as much gas mileage or flat idling as a bridgeport, somewhere I heard a large street port gives like 15-20% increase in power... anyone know if thats true?
1989 RX-7 TII --- Just got rebuilt and street ported RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II, 720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads HKS Blow-Off Valve, Stainless brake and clutch lines |
Re: Turbo Port
Ok, awesome. Yeah, i remember reading something about that, but I wasn't completely sure. So a turbo would need a little more vaccum to spool faster right? (this is just to help me understand what works well and how it works, and why it works)
Re: Turbo Port
Although a street-port does help, to be honest with you, a Turbo Rotary that is street driven really doesn't need a port at all.. just optimize the pressure-charging. better IC, C02 Spray, better piping etc etc.
I wouldn't go yanking our your engine that still runs fine to port and rebuild. |
Re: Turbo Port
For anything daily driven, I recommend a street port. The term, however, is very ambiguous as not all "street ports" are the same. By as many people there are performing this kind of work and porting labour, there's just that many opinions and porting styles on it. The idea behind it, however, should be to reduce the pressure drops found in the transitioning of the port tunnel to the port outlet of all four intake ports as well as reducing the boundary of each. In short, fix the problems with the cast stuff and help keep the intake charge velocity as high as possible. B
__________________ Brian D. Cain -/- Grand Prairie, TX -/- [email protected] [email protected] BDC Motorsports - Performance Rx-7 12A/13B Rebuilds, EFI tuning, etc. MSN [email protected], Yahoo! bdc196, AOL Symajhi, ICQ# 1733105 http://bdc.cyberosity.com -/- http://groups.yahoo.com/group/HaltechSupport |
