I have a 92 ranger that has a light problem.
I was driving at night and the drivers side headlight got dim then burned out. I replaced the bulb, but then it happened again, within a minute of turning the lights on. The passenger side light had no problem. I first suspected a short, so i checked all the wires for cracks/burns, and i also made sure the sockets were not melted and shorting out. As another try, i took out the bulb from the passengers side and put it in the drivers side and turned it on, there was no problems, but as soon as i put a bulb in the passengers side the drivers light would dim, but i shut it off before it died. It was obvious that the light was getting very hot, but i couldnt figure it out. The lights work good with one side or the other connected, but not both. I used 2 different brands of bulbs, both were the standard 9007. Recently, the high/low switch in the steering column was replaced, along with the master lighting switch. All the wiring seems to be in good condition. I really have no fricking idea what is going on EDIT: I meant to type 9004 as the bulb number, not 9007
Do sober what you say you will do when you're drunk. that will teach you to keep your mouth shut. Last edited by lakerfan1784; 03-09-2004 at 02:57 PM. |
