Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-08-2004, 08:34 PM
87camry1 87camry1 is offline
Question 87 Camry automatic seatbelts
The automatic seatbelts stopped operating and are locked in the forward position. I cannot find any blown fuses. I can hear a faint arcing/shorting(?) when initially turning the ignition key. In trying to trace the source, I pulled off the cover tray on the console. Does the seatbelt warning module control the seat belt motors or just sense that belts are engaged if the seats are occupied? If so, is the module avaialable aftermarket or dealer only? If not, any other ideas would be appreciated. I have used the Haynes repair manual for years but it skips this section and refers all repairs to the dealer.
Thanks in advance for any assistance.
DanM
Old 03-09-2004, 10:19 PM
drdaveleister drdaveleister is offline
Send a message via AIM to drdaveleister
well i kind of ran into the same thing on my 91, and so did my buddy, and we both kind of assumed that it had to do with the emergency release lever. so we checked that out... didnt get us a whole lot, so we looked for fuses. i didnt find anything at first, but i searched a little bit hard and found an 80 amp fuse for the alternator to the battery that was near death( i didnt replace it then but a few days after it blew and nothing would work). so after it blew, i did some work to see if i had any bad shorts, because its fairly hard to blow an 80 fuse. i regrounded everything i knew of, checked the wiring of the front dash and console, and pulled each and every fuse i knew of, and cleaned them. i also replaced the battery terminals.
i dont know what i did exactly, but after i did all that, my seat belts worked fine. i dont know exactly how that emergency release works, trust me ive tried to find out. but i would imagine that it does affect the motor in some way, in order to release the mechanisims that move the belts to the front of the door safely in case of an emergency. my best advice to you is to check your grounds and terminals first. then rip it apart if it doesnt work. also... do you still hear the buzzer....i could still hear the buzzer on mine, but my friends had no buzzy, and he still to this day has yet to fix it.
drdaveleister
91 camry all-trac. 3s-fte.
9 psi boost.
a magic button (100 shot n02.)
trd suspension.
rally. with naked ladies in the back seats.
02 focus
still planning. but plenty of naked ladies(i wish)
Old 03-09-2004, 11:35 PM
manyodas88 manyodas88 is offline
above the fuse block under the dash there should be three 30 amp circut breakers ( at least there is on my 88) i believe the top one closest to the firewall is the seatbelt breaker. try switching it with one of the others to see if it's bad. i think if i'm not mistaken tat these are resetable there is a small pin hole to do this. they are quiete expensive also($24) at toyota
Old 03-22-2004, 09:07 PM
Help!
I would appreciate additional suggestions.
I have pulled the console, checked wiring and replaced the seatbelt warning relay.
I tried to trace the wiring back to the fuse block. I have pulled and cleaned fuses and wires. I have tested and swapped the 30A breakers.
The fusible links appear 'brand new'. The links are full and show no signs of oxidation or melting.
I have traced wiring back under dash but cannot locate the automatic seat belt computer. Is it under the dash? If any one knows its location, please provide.
Thanks in advance.
Old 03-28-2004, 10:18 PM
ray1 ray1 is offline
Re: 87 Camry automatic seatbelts
I had a problem with my drivers side automatic seat belt not working. I removed the drivers side door panel and began to inspect the wiring harness located in the door and found a wire to be broken. I had a parts car that is the same model and used the wiring harness out of it.My seat belt started working after replacing the harness.All I would of had to do was fix the broken place in the other harness and it would have worked just fine.I am going to fix the old harness and put it up in case
I need it some time later.
Old 04-02-2004, 12:53 PM
Mark A Mark A is offline
The wiring to the door eventually breaks down due to use. It can cause other failures too such as power windows and power locks.
Old 04-26-2004, 11:25 PM
Raul Lugo Raul Lugo is offline
a broken wire between the door hinges. the end of this wire is located under the door panel connected to the door lock. there are 3 wire must like it is a light brown one. run a test wire to the inside to find out.
Old 04-22-2006, 12:22 PM
91 TOY CAMRY 91 TOY CAMRY is offline
Ihave Same Problem Driverside Seatbeat Not Working And Dome Light.both With Power Used Test Light I Got The Seatbelt To Work.any Suggestions Thanks
Old 04-25-2006, 03:33 PM
nohablaingles nohablaingles is offline
There's a recall on seat belt retractors. Go to NHTSB site and enter your VIN. You should be able to pull up info. The next difficulty is getting the dealer to perform a recall on a car that old.
good luck.
Old 04-26-2006, 02:22 PM
typesix typesix is offline
The recall was for the manual lap belt portion of the system, not the motorized shoulder belt.
Old 04-29-2006, 02:26 PM
I Got A Dealer To Run The Vin To Old But He Told Me To Bring It In A Tech Can Run It On There Computer For Older Cars. I Tryed Switing The 30a Breakers Didnt Work
Old 05-01-2006, 10:15 AM
augie7071 augie7071 is offline
Had the same problem with my 89 camry. it was the wire haness between the door and body. the auto locks and windows were not working either. took the harness out and 10 wires were broke or nearly broke. I used butt to butt conectors & left the plastic kick panel off to give it more room to flex when the door opens and closes.
Bill
91 Camry Automatic seatbelt idmetro Camry/Camry Hybrid/Vista 4 11-15-2009 07:35 AM
Annoying automatic seatbelts anyone? G2FL Cosmetics 5 08-14-2005 07:18 PM
Automatic Seatbelts crcavallo SC/SL/SW 1 01-26-2004 12:47 PM
civic automatic seatbelts piss me off Thad Car Audio 0 03-28-2003 07:38 PM
damn automatic seatbelts GScivic7 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 11-13-2002 09:38 PM
