Old 03-08-2004, 07:31 PM
d_fl8ted1 d_fl8ted1 is offline
Question egr valve problem on a venom intake manifold instal please help
i am working on a 1997 mitsubishi eclipse 2.0 liter dohc 420a automatic, i am trying to install the venom intake manifold on this car but i have a problem, i have figured out how to tap all the sensors needed for the car except the egr valve... is there a way to bypass this valve to make this manifold work and does the car even need this valve to work properly... please inform
Old 03-08-2004, 07:44 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: egr valve problem on a venom intake manifold instal please help
Nope you dont need the egr...
I took mine out yesterday
It makes your intake filthy anyways.
Follow this to block it off...
Find your egr valve, it is to the right of the exhaust manifold on the side of the head.
Then find the metal pipe running back to the intake manifold.
Remove the 2 8mm bolts that attach the pipe and the egr valve.
Remove the 2 8mm bolts that attach the pipe and the intake manifold.
Remove the 2 10mm bolts that attach the egr valve to the side of the head. (use wd40 mine were seized/rusted)
Then pull everything out of there.
You can buy blockoff plates from MOPAR or howellautomotive.com or you can cut 1/8" metal in the shape of the gasket, and put washers on the bolts and put it back on.
You will now have a CEL for the missing egr, that can be fixed with a resistor (this does not work 100% of the time sometimes the cpu gets smart and comes back on) You use a 1.2k ohm 10w resistor.
However, you still will get a egr insuffient flow code 32, once in a while.
For Sale 98 Eclipse GS, 5 spd
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
Venom Intake Manifold Problem, please help sx250xl Off-Topic 1 12-03-2003 03:42 AM
EGR Valve problem...please help ShaenaSteel Accord/TSX/Accord Hybrid 1 11-08-2003 10:03 AM
