i need help on underhood relays
I need Help bad when i bought my 87 wagoneer i noticed a wire used to jump a two terminals together on one of the 4 under hood relays and lately my jeep has been dieing with out any warning but this morning when it died i tried jiggling the relay like usual but nothing happened my fuel pump won't kick in but everything else works from what i can tell just no fuel and i've tried a new relay but nothing happened can any body tell me what the the 4 relays are in order or ever had it happen to them or any idea's it would be greatly Appreciated!i
Re: i need help on underhood relays
My 88 comanche has just started doing this, but when It happens my starter clicks once, then I lose all power till I jiggle the relay wires. I'm guessing there is a short in one wire thast needs to be fixed. Good luck!!
Re: Re: i need help on underhood relays
i finally found the problem its a short about 10" from the relay but the problem is i can only find it when my jeep has been running and the wire is heated up a little bit because when i found it my jeep was just running and i could barely jiggle the wire and it would break connection but when i went inside and came back out 10 minutes later and tried the same thing it wouldn't go out at all.
