Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 03-08-2004, 05:23 PM
comp comp is offline
Unhappy 88 die's when warm?????
posted for a buddy, it's a 88 w/302 he has installed new, coil & wire's
coil , pickup coil , dist.module. when it get to operating temp it shuts
down, also he said it's not overheating, just up to normal???? any help
thanks COMP
Old 03-09-2004, 12:12 AM
OK is there a forum that has a lot of Bronco owners, like vary bizzy thanks
Old 03-09-2004, 09:29 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: 88 die's when warm?????
Ok, sounds like the emp sending unit to me. Does he have a mechanical gauge he can hook up to it? If the sending unit is bad, then the computer thinks the engine is hot when it isn't and switches from open loop to closed loop mode, now using the O2 sensors, and then leans out and dies. Thats one possibility. There is another possibility that it is a sensor or something getting ready to die, but i think the only one which would cause this is is either the MAP sensor or the IAC sensor, but that is a long shot that it would quit working right when the engine is hot. I would say the temp sending unit. By the fordtrucks.com has a nice bronco section and pickup section. Tell em that 78fordman sent ya.
Old 04-09-2004, 04:05 AM
kingmt kingmt is offline
There is several things it could be. Dose it have a check engine light on? Did you take the module to get it tested? It can air lock in the fuel system(bleed it at the shrader valve). It may be the pickup in the dist.
Old 04-20-2004, 09:56 PM
97chevyman's Avatar
he already replaced the pickup. But in order for it to die when it is warm, there are only a couple things. Temp sending unit, iac control, possibly low fuel pressure, but thats stretching it.
Old 04-21-2004, 01:59 AM
Sorry forgot to post,,, he replaced the new pick-up with another and it's OK so the new napa pick-up was bad in the box.... that don't happen to often !!!
HELP! 92 Ranger doesn't want to move when warm!! fordstranger Ranger | Courier 3 07-16-2009 08:33 PM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 09:19 PM
99 alero die's when driving jeresymay Alero 0 09-21-2008 10:44 AM
88 302 die's when warm, comp General Discussion 0 03-08-2004 05:26 PM
loud hiss/whine when at first, then goes away when warm sailmen Rodeo | Passport | MU 8 12-22-2003 06:05 AM
