Old 03-08-2004, 04:19 PM
cpbaker cpbaker is offline
Engine falls flat upon acceleration
My son has an '89 civic 1.5. When he steps on the accelerator, it falls flat and then just chugs. It starts good and idles good, just can't push on the gas pedal without it chugging. It looks like it's getting plenty of fuel. The top injector is puting out plenty of fuel.
Can someone give me some ideas what to look for?
Old 03-08-2004, 07:09 PM
Hybrid1990crx's Avatar
Re: Engine falls flat upon acceleration
spark. check to see if the plugs are fouled.
Old 03-08-2004, 10:21 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
may sound dumb, but have you checked the air filter?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-09-2004, 10:29 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
That may be the problem, it's flooding out on you. Might be time to have the fuel pressure and regualtor checked, for too much pressure in the system. There was also something about those injectors, would tend to leak around the seam. Also, when was the timing last checked...
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 03-09-2004, 10:46 AM
Thanks for the info.
Here's what we have already done.
Removed the air cleaner
Disconnected the top injector (no change), can the lower one flood it?
Changed plugs and wires
Cleaned the throttle body
Checked the lines (air & fuel)
Checked catilytic converter to make sure it's not plugged
My son says he checked the cam timing marks. He changed the belt some time back, but it ran just fine for a while. I want to open it back up and check it one more time, and also check the valve lash.
Old 03-09-2004, 11:01 AM
Has the plugs been pulled sense this has been happening, if so how did they look as far color goes...?
ZYDNE SECU, 450's
Old 03-09-2004, 11:48 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
the upper injector is only the auxillary injector. You're not going to feel any change by removing that one. That injector is only programmed to spit fuel near or around 3k RPM. The lower one which is the main injector is on all the time. It wierd but technically, dx's only run on one injector till it hits a certain rpm point...then the auxillary injector kicks in...sorta like a mini vtec.
Do you have a check engine light? If so, look at the ECU and count the blinks.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-09-2004, 01:31 PM
Re: Re: Engine falls flat upon acceleration
Interesting, the top injector starts squirting a little just off idle..
OK, here is what I have done today...
Mind you, this is not my car and I'm not familiar with a honda...LOL
I checked the code: It blinked 16 short times. I checked it several times to make sure I saw it right...
I removed the injectors and cleaned them as best I could.. No difference. It will not run above idle, just chugs... And still 16 blinks...
I disconnected the bottom injector and it ran the same. Still idled but chugged off idle. Injector?
I also tried pouring a little fuel down the intake while opening the throttle to see if it needed more. No luck - flooded it...
Oh, and it seems to have plenty of vacuum...
Old 03-09-2004, 07:41 PM
OK, my son just showed up. I showed him what I found. He showed me that if you reset the computer, there are no error codes. There are NO error codes after resetting the computer. Now I'm lost again...
Old 03-10-2004, 08:18 AM
Just keep an eye on it, thats all you can do right now, and it's really not that uncommon. To reset the ECU and have the code(s) go away...
When you pulled that one injector, the ECU went into "Limp Mode" and just used the remaining one full time. Thats probably why you did not notice any real change at first.
Here are some things to check "if" it comes back - Code 16 is probably the Main Relay, however it could still mean a Bad Injector or Resistor Box tho.
ZYDNE SECU, 450's
Old 03-10-2004, 09:22 AM
bambam89lx's Avatar
AF - Advisor
I would say to replace the main relay since it seems as tho ur injectors are working and you don't have an injector resistor box. (it was only utilized in the si and not the dx). Oh yah, that code 16 isn't anything to worry about, I'm sure it only appeared after you undid the injector plug.
Old 03-10-2004, 11:03 AM
Can you tell me where the Main relay is??
As far as the Code, I think you're right. It must have came on after I unplugged it, just didn't realize the computer had a memory and had to be erased...
Old 03-10-2004, 02:45 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
There's a ton of info on removing and repairing/replacing the main relay here:
http://www.google.com/search?q=civic...utf-8&oe=utf-8
Cheers
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 03-10-2004, 03:05 PM
Thanks, I'll check it out today...
And WOW!!! 4500 posts? WOW!!!
Old 03-10-2004, 11:26 PM
WindyIce's Avatar
WindyIce WindyIce is offline
Send a message via ICQ to WindyIce Send a message via AIM to WindyIce
I had a similair problem. My car would boog around 3k rpm. Decided to swap my main relay for it has to do with the fuel pump. Fixed the problem. Went and picked it up from the dealer for 45. Problem fixed..................
**!!4thgen in the projects!!**
B16A LSD JDM With Entire Car
engine stumbles upon acceleration jbryant Silverado 7 06-03-2010 06:11 PM
93 rough upon acceleration cstruc Regal 0 04-25-2009 12:45 AM
1990 Grand Prix engine hesitation upon acceleration mp1642 Grand Prix 5 04-02-2009 01:52 PM
High Pitched Engine Sound upon Acceleration sassysoonergirl Rodeo | Passport | MU 3 02-13-2006 04:11 PM
Falling Flat 91 4.0 liter Laredo phil11 Cherokee 0 09-06-2004 02:13 PM
