Old 03-08-2004, 03:03 PM
CananBall81 CananBall81 is offline
Send a message via AIM to CananBall81
2.3 distributor clamp?
My First time trying to adjust the timing of my 2.3. How do i access the distributer clamp bolt? I can't get in from the top, and from the side there is no clearlance to move the wrench. Is there a specialty tool for this job or, do i have to remove the PCV valve seat hose to loosen the clamp, then re install it to start the car and adjust timing, then take it off again the tighten the clamp? Please help!
Thanks
Cananball81
Old 03-08-2004, 03:48 PM
Re: 2.3 distributor clamp?
I think i found a specialty wrench for this job. All of the stores carry a 9/16 or 1/2 size, i only checked it out quickly, but i think the clamp bolt was a 17mm. Anyone know?
Old 03-08-2004, 05:40 PM
Dauber Dauber is offline
17mm, just checked my car. I found remove the PCV valve, push the hose down, take off the timing cover, this should give you more room to shimmy the bolt loose with the wrench, good luck!
Old 03-09-2004, 10:37 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i pulled the plug wires (or moved them out of the way) and stuck a 3/8 drive 17mm socket down there with a big long extension. worked for me. also, if you get an open-ended oil filter wrench, you can turn your dist without loosening that bolt. also, grab a hold of the electrical connector on the side and give it a tug. that's how i adjust mine. dauber, why pull the timing cover off? that's such a pain, gotta take off the belts and water pump pulley to get at it!
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 03-10-2004, 10:42 AM
was able to get at it with a crowsfoot wrench pretty easy, thanks
cananball81
Old 03-13-2004, 02:30 PM
Never thought about that Stangnut86, the last time I adjusted the timing was hmmm...three years ago, lack of tools, but I see what your saying now when I double take a look at the engine, I'll keep your trick in mind, thanks. I always got to do things the hard way the first time, then find easier ways the second time!
Old 03-13-2004, 05:10 PM
Turbo_Raccoon's Avatar
Turbo_Raccoon Turbo_Raccoon is offline
Send a message via AIM to Turbo_Raccoon Send a message via MSN to Turbo_Raccoon Send a message via Yahoo to Turbo_Raccoon
when i adjust timing i take off the distributor and move it out of the way with the wires still connected and then take off the pcv valve and hoses the losen the bolt then figure out ur timing then do a reverse
1979 Ford Mustang 2.3 Turbo.140 Horsepower to the wheels.4 Speed. 3.45:1 gear ratio.
Traction Control light Cancel comes on, Clamp Alignment azakram CTS and CTS-V 0 09-11-2010 01:11 PM
95 4.3L CPI distributor clamp bolt...!?!? $%$#! vballfun Blazer 7 07-09-2006 07:29 AM
'87 2.8 distributor hold down clamp Kryppy Camaro Discussions 1 06-07-2006 10:49 AM
differences between 2.2/2.3/3.0 ruffio1842 CL | Inspire | Saber | TL 1 01-12-2006 03:37 PM
3.1...2.2...3.1...2.2...with enough "persuasion" ne thing works aviator18 Cavalier 0 06-07-2004 11:21 PM
