Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-08-2004, 02:31 PM
radeohedca radeohedca is offline
No start/no spark...Ignition questions
My '92 Bonny will not start. There is no spark at the plugs
(there is fuel at the injectors).
I checked the 3 coils (Magnavox system with 3 coil pairs)
and they appear to have the proper resistance across the
primaries and secondaries so I suspect it is something further back.
How does one determine whether the problem lies with
the ignition module, PCM or some other component ?
I miss the days of the old HEI distributor with the integral coil
and hall effect module. It sure was a lot easier to troubleshoot
Thanks, Hugh
Old 03-09-2004, 01:28 PM
jkinney jkinney is offline
Take it (ignition module) into Autozone or comparible parts store, they test them regularly. Do not need coils on them, have them test it three times to make sure it gets good and warm to simulate its under hood operating temp.
Old 03-09-2004, 07:08 PM
michelq michelq is offline
Re: No start/no spark...Ignition questions
lotes of times the crank sensor goes bad
make sure you have ign power to madule
Old 09-16-2004, 10:40 AM
ecrumb ecrumb is offline
Lightbulb
radeohedca,
I have the same problem with my 1990 Bonne SSE. Check my threads and you will see all the things I have done that so far, hasn't worked. Since we seem to have the same problem, maybe this way we can pool our efforts and come up with the answer faster.
Hopingly ecrumb
Old 01-21-2005, 07:46 PM
oldmanschild oldmanschild is offline
Send a message via AIM to oldmanschild
Did you see if the coils are getting proper ground? if they are then my advice would be stop beating around the bush whith guesses and just get someone to hook it up to a snapon scanner or anything of that sort
2001 Olds Intrigue 3.5 No Spark tyler219 Intrigue 2 06-04-2009 12:48 PM
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 11:55 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
97 Tahoe won't start. Cranks, has no spark rookieshaper Tahoe 2 02-24-2009 09:40 AM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
