Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-08-2004, 01:08 PM
mistga mistga is offline
Adjusting 96 Explorer Parking Brake
I would like to adjust the parking brake on my Explorer, but I don't see a place on the cable to adjust its tension. Does anyone have any info that would help?
Thanks,
Grant
Old 03-09-2004, 04:41 AM
srercrcr srercrcr is offline
Re: Adjusting 96 Explorer Parking Brake
Wish I had an answer for you, but I do know that if the rear brake linings are worn, that is making the parking brake out of adjustment.
Old 03-09-2004, 06:17 AM
amac209 amac209 is offline
Send a message via MSN to amac209
do you have rear disks?? if you do the parking brake is actually a drum inside of the disk but you already knew that right?? okay to adjust the parking brake there is a little star wheel you need to turn with a brake spoon if you pop the rubber insert out of the backing plate and shine a flashlight in the hole you can see it. i like to tighten up each wheel untill it locks up then loosen it off till it turns freely. hope this helps you guys!!
Old 03-09-2004, 07:14 AM
Opera House Opera House is offline
These have a history of falling apart even if you never use them. This is likely the cause of your problem. Inspection is nearly impossible because of the rust edge that forms at the back of the drum. If they weren't bad, they will be when you remove the drum.
parking brake vs. car in park...help! CVCchic85 '96-'00 Civic 1 08-09-2010 09:56 PM
Parking brake tbird -92 5.0 bennylw Thunderbird 4 06-14-2009 03:24 AM
'99 Explorer parking brake dlw Explorer | Explorer Sport Trac 9 07-26-2007 03:16 PM
Adjusting the parking brake ecamc Outback 1 02-24-2007 10:48 AM
98 Explorer parking brake light and brake itself Bugeye60 Explorer | Explorer Sport Trac 3 10-12-2006 04:53 PM
