Old 03-08-2004, 01:02 PM
tomstolz tomstolz is offline
creaky doors on 04 extended cab
I searched through the threads and didn't find any that sounded like my problem, so here goes. I have an 04 1500 extened cab, I have had it about a month and a half. The rear doors seem to intermittently creak. Seems to have nothing to do with how hard they are shut. Sounded like maybe the rubber seals rubbing together on the front and rear door "seam", so I sprayed silicone lubricant on them...didn't seem to affect it at all. Still making noise...anyone else noticed this on their truck, or taken it in and had it fixed? Hope this isn't just a design flaw with the rear opening doors. Any info would be appreciated. Thanks. Tom
Old 03-08-2004, 01:06 PM
sorry, should have been a little more specific...doors creak when running down the road...mostly on bumps or pavement changes...very annoying "irrck" sound...thanks.
Old 03-08-2004, 01:59 PM
huminski's Avatar
huminski huminski is offline
Re: creaky doors on 04 extended cab
My 2004 does the same thing. Annoying as hell. Seems to come from the area between the front and rear doors. Let me know if you find anything.
Steve
2004 2WD 5.3 Xcab StepSide
Old 03-08-2004, 06:54 PM
JDeere_Matt JDeere_Matt is offline
Send a message via AIM to JDeere_Matt Send a message via MSN to JDeere_Matt
I have a '04 and it does the same thing. I am taking it on a 1800 mile trip next week. I can't wait to hear that all the way there and back.
Old 03-10-2004, 11:08 AM
danv danv is offline
I have an '03 Extended Cab Silverado and mine was doing a similar thing, with a high-pitched "crick-crick" sound, almost like a diamond on glass. I solved the problem by putting some white lithium grease on the two "hoop" catches at the top and bottom of the rear door openings.
Hopefully that will help you have a more peaceful trip.
Dan
Old 03-10-2004, 01:52 PM
Re: Re: creaky doors on 04 extended cab
Dan
Thank you so much Dan...I will give that a try...
Old 03-10-2004, 11:37 PM
Thanks, I kinda figured it was coming from that general area. I will give it a try. Matt
Old 03-11-2004, 08:00 AM
huminski's Avatar
I'll definitely try that, I commute over an hour each way every day so it's really starting it get irritating!
THANKS!!
Steve
Old 03-16-2004, 09:28 AM
it worked, the creaking is gone...thanks
Old 03-22-2004, 04:46 PM
huminski's Avatar
Greased up my back door last night (that doesn't sound right....lol) and drove all the way into work this morning without a single 'squeak squeak' out of the door. It was beautiful. Thank you!!!!!!!!!!!!!
Steve
Old 03-22-2004, 09:47 PM
TXAGG05 TXAGG05 is offline
The same thing happened to mine on my way to Baton Rouge at 2AM back in November of '02. I didn't have any lithium grease so I used deoderant(stick type) and it worked for a while. Don't lose your white lithium grease, because it may wear off. Mine has worn off once and I had to re-apply it.
Jeb
P.S.-I usually hit both the top and bottom "loops" as well as the "loop" for the door latch very lightly. Do ya'll do the same?
Old 03-23-2004, 05:54 AM
huminski's Avatar
I didn't have any lithium grease, I used bearing grease.
Steve
FOR SALE 1991 Crew Cab The cab scarycary Cars/Parts for Sale/Exchange 0 06-24-2010 10:50 AM
1993 Dodge Dakota extended cab Jayr37A Dakota 1 04-22-2010 06:04 PM
? about regular cab and extended cab rear beds. Fordy8man S-10 2 06-27-2005 01:26 AM
Removing extended cab door panels grass roots Ranger | Courier 0 04-02-2005 05:44 PM
2003 Extended Cab Toyota Tacoma TRD vs. 2003 Extended Cab Chevy s-10 ZR2 Pick Car Comparisons 2 07-02-2004 03:09 AM
