Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-08-2004, 11:02 AM
digital_abuzer digital_abuzer is offline
Question PCM Location Please
Where is the PCM located in my car I need to replace it. Its is a 94 Olds 88 Royale 3.8L v6. A friend told me it was under the hood but that is the electronic brake system, he must be wrong. I know that the computer diagnostic hookup is under the driver seat console (under wheel) near the fuses. Is the PCM around that area or is it somewhere else?
Thanks alot! Ive been needing to replace this damn thing for a while and I finally got enough cash to go to the junkyard and get one. Its the life of the college student.
Old 03-08-2004, 01:29 PM
harlancook@earthli harlancook@earthli is offline
it should be under the dash on the passenger side behind the glove compartment.
Old 03-08-2004, 02:38 PM
Thanks dudes, and would I have to remove the glove compartment to replace it?
Old 03-08-2004, 07:16 PM
yes the glove box needs to come out.
Old 03-09-2004, 07:03 AM
Alright thanks for the tips, that should be a real bitch!
Old 03-09-2004, 06:20 PM
michelq michelq is offline
Re: Pcm
NO you do not need to glove box just remove the bottom cover and here you are
1999 sable fans not coming on long enough, PCM, CCRM. cooling timetrax Sable 5 06-05-2015 08:52 PM
Got P0601 Internal Control Module Memory Checksum Error replace PCM or RE-Programm? gujju Caravan | Voyager 1 09-30-2010 11:01 PM
03 LS V6 with coil problems then PCM failure.. PCM module swappable? jasonsjwou LS | MKZ 4 07-29-2009 12:55 PM
Crankshaft Sensor? PCM? Camshaft Sensor? elninoeso Ram Van 14 06-10-2009 12:19 AM
Reprograming PCM Jerry Baumgarner Engine and Transmission 1 01-30-2002 06:54 AM
