Old 03-07-2004, 05:18 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
95Eclipse GS-T Mods
Sup I have a manual boost control,k&n filter with mass airflow adapter,UICP,1G BOV,and a boost gauge.
What size exhaust should I go with.
What is the Stock PSI on my car,What should I boost it to.
The car has been sitting up for about 2years and finally have a new motor how hard is it to clean the Intercooler out.
Any other BANG forBUCK mods ya'll know of that would help.
PCE
Old 03-07-2004, 05:23 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: 95Eclipse GS-T Mods
3in since your turbo
For Sale 98 Eclipse GS, 5 spd
Old 03-07-2004, 05:36 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
1. You won't benefit from 3 inch over 2.5, but if you are going to need it eventually (many more mods) then go for the 3 to save some money later.
2. Stock is 15psi. Most people recommend no more than 17-18 on the t25 (stock 2g) for reliability, however some people like 95 GSXracer wouldn't hesitate to run whatever will give more power
3. Remove the intercooler and use gasoline or rubbing alcohol to clean the inside. Exact procedure HERE.
4. Full turbo-back exhaust, intake pipe... then you are pretty much ready for a serious upgrade, the new turbo. That will include all sorts of supporting mods. Fuel pump, injectors, maybe FPR, Air/Fuel controller, clutch, FMIC (depending on how big turbo may not be necessary, but always helpful) are all in the future.
Good luck
Old 03-07-2004, 05:41 PM
Cool thanks bunchs.As soon as I get some Pics I 'll post them.PCE
Old 03-07-2004, 05:50 PM
ashah000's Avatar
Re: Re: 95Eclipse GS-T Mods
Interesting... then do you think 2.5 for the NT is too much.
Because mostly everyone on 2gnt says 2.5 and if your going turbo 3"
Old 03-07-2004, 05:59 PM
I have heard the same thing, 3" for the turbo and 2.25 r2.5 for the non turbo
Old 03-07-2004, 06:44 PM
JoeWagon's Avatar
Banned
You will get boost creep a lot of the time with for example an EVO 16g and 3 inch. It's just bigger than you need. 2.5 is plenty for a small turbo, but like I said, if you have plans to go bigger, 3 inch is good. It's not bad any time except for boost creep, really.
Old 03-07-2004, 10:19 PM
oh yea you can gaurantee I will be going bigger.Its like they always say "GO BIG OR GO HOME"Thanks for the help
PCE
Old 03-08-2004, 02:45 AM
kjewer1 kjewer1 is offline
AF - Advisor
2.5 or 3" will cause boost creep on just about every internal WG turbo there is, if the appropriate porting isnt done. See www.vfaq.com for what porting is required (not the o2 housing like everyone thinks )
16 psi will yield the most power on 95% of the t25 cars out there. I have looked into this extensively when I had that turbo. I tried everything myself, and that is the conclusion i came to. Assuming pump gas of course. I ran over 20 psi on race gas and went a bit faster (half second).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Does the ebay resistor mod really work?? hoopdaddy6 Car Rumors & Concepts 1 12-17-2012 06:58 PM
305 mod suggestions gdawgdb Engine and Transmission 2 05-20-2009 03:05 AM
For Sale Great Car mods for basically any car! Jstone616 Cars/Parts for Sale/Exchange 0 05-18-2009 02:25 PM
GS-T mod iGyx Off-Topic 16 06-02-2004 02:00 AM
gs turbo mods talontedEcLiPsE Off-Topic 1 10-06-2003 12:51 PM
