Old 03-07-2004, 06:18 PM
judd777 judd777 is offline
Question Poor milage and a miss at full throttle after head/intake gaskets job.
My 1997 5.7 suburban got 17-18 MPG before I had head gaskets and intake gaskets put on it. Now it gets 13 MPG around town or down the interstate. I have check 4 tanks and the milage has not improved. Is it possible that the garage did not get the distrubutor on correctly and it is causing a problem? It has plenty of power but has a miss under full throttle.
Old 03-07-2004, 07:15 PM
lmnmarang lmnmarang is offline
I'd take it back to the shop and have them recheck the timing,plug wire routing,and mack sure they didn't tear a plug wire.Try pulling you sub.in the garage,with the garage door cracked just a bit(fumes)turn out all the lights and see if you see any spark under the hood.hope this helps and hope you get the problem resolved.
brake pedal going to the floor after my intake gasket job RustX7 LeSabre 3 08-23-2010 05:02 PM
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 04:56 AM
97 jimmy no start after intake gasket job taxidermist Jimmy 2 03-14-2010 08:58 PM
Intake gasket or head gasket?? mandymae104 Century 3 07-10-2009 10:31 AM
engine sounds and runs horribly rough after head gaskets replaced bigdaddypsb Grand AM 6 03-07-2004 01:23 PM
