Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-07-2004, 01:02 PM
Ground_fx Ground_fx is offline
Loose Clutch Pedal
Hi, i drive a 1989 Honda Prelude SI
and just out of the blue, one morning, i went to go move the car, and when i pushed the clutch down to start it up, it went straight to the floor. There is no pressure in the pedal, and i can't shift into any gears. Does anyone know what the problem is and how to solve it?
thanks
Old 03-09-2004, 10:14 AM
SRV BOY SRV BOY is offline
Re: Loose Clutch Pedal
Either the clutch arm(i can't remember the correct term) is gone or something is wrong with the clutch itself. I had the same problem and found out that the master clutch was leaking fluid.
Old 03-09-2004, 08:12 PM
thanks for the response, i took it in, and they just said it needed to be topped up. But i have only had the car for 3 weeks now, so hopefully it just needed topping up and the mechanics aren't trying to use me for money and it ends up being something serious in the long run
Old 03-10-2004, 01:27 PM
They just adjusted the clutch probably or something like that, you mite have to buy a new clutch down the road, it would cost you like 500
