Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-07-2004, 11:36 AM
fakopacs fakopacs is offline
Question 1999 Rodeo - ABS motor keeps runing (even with the key off)
I found this issue on this board (and my car of course) and checking the www.alldata.com I also found some recalls on this topic (at least I hope). My question is if the recalls mentioned here do address this issue or not. The site is http://www.alldata.com/TSB/29/99292332.html and the recalls are listed under "Safety Recalls":
TSB Number Issue Date TSB Title
02I-002 JUN 03 Recall - ABS Coil Integrated Module Replacement
SB03-09-S001C JUN 03 Recall - Brake Coil Integrated Module Replacement
Should I expect the dealer to fix this for free or am I being too naive.
Thanks
Old 03-07-2004, 02:44 PM
Cat Fuzz Cat Fuzz is offline
Safety recalls should be free.
Old 03-07-2004, 06:56 PM
Re: 1999 Rodeo - ABS motor keeps runing (even with the key off)
Thnaks for the reply, but my question is if anyone knows if any of those recalls are about my problem?
Old 03-07-2004, 10:57 PM
Just take it to a dealer. They can perform the work that needs to be done and they should be able to tell you if your problem is related to the defective items.
Old 03-08-2004, 10:17 AM
rodeo02 rodeo02 is offline
Re: Re: 1999 Rodeo - ABS motor keeps runing (even with the key off)
Yes. The recall will resolve your ABS issue at no cost to you. In the mean time, just yank your ABS fuse to keep the ABS pump from running down your battery.
G/luck
Joel
Old 03-11-2004, 07:29 AM
Mikeybat Mikeybat is offline
I had to pull the fuse also to stop the ABS module from running all the time. Going into the dealership today to have it replaced.
Personally, I feel the braking is much better without the ABS, hopefully the new module will also resolve that issue.
Mikeybat
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
