Go Back   Automotive Forums Car Chat > Buick > Century
Old 03-06-2004, 11:10 PM
1969Stang 1969Stang is offline
Send a message via AIM to 1969Stang
a few questions
1) blinkers and powerwindows why are they sooooo slow. click............................................. ...........click......lol....you get the point.
2) at idle car feels like its miss firing....but no check engine light or anything....and yes it does come one when you put the key to the on postion....so i know it works.
3) brand new battery and alternater......and that damn battery light comes on....i think it does it just to piss me off...did a charging system check at work.....and everything is good....so it says....car isn't dead when i go to start it...so i don't know...normally happens at nights with the lights on....or when i step on the brakes with the head lights on...or when ever it wants to go on......whats the problem...
4) last but not least...had the transmission rebuilt about 4 months agoish. when i start to drive the car....it shifts up....really fast....no kick down or anything...barely hit the gas and that damn thing will shift into overdrive before you know it....and sometimes it won't even get out of 2nd....going on the 71.......55mph and the cars rpms are high as hell.....help.....whats wrong........
thanks.......
Old 03-09-2004, 08:27 AM
RABarrett RABarrett is offline
Re: a few questions
This situation sounds like a defective connection, causing certain components, like the ignition, dash, etc. to see low voltages. All of these things will lead to a battery light. You might try going through the vehicle, especially near the fuse box, looking for dirty or loose connections. Look for a common point where all of the above components tie together. Defective ground connections, loose power connections, etc. Ray
Old 03-15-2004, 11:22 PM
Re: a few questions
thanks
