Old 03-06-2004, 10:02 PM
RalphB30 RalphB30 is offline
Send a message via MSN to RalphB30
Fog Lights
Has anyone found a way to take control of the fog lights on the Grand Caravan. I have a 2004 SXT (I think SXT) and want the fog lights to stay on when I turn on the high beams. I found a wiring detail for my 2004 F-350 and like the way it lights up the road.
Thanks
Ralph
Old 03-14-2004, 12:20 PM
MegaMax MegaMax is offline
Send a message via AIM to MegaMax
I have done this Mod to all my cars..
Open the relay box, locate the relay, find the Trigger lead. The OEM setup has it inline with the headlights. So it shuts off with them as the highbeams come on. Run a wire over to your corner bulbs. (they say on with the high beams on)
Test your new lights..
Cover it all back up and your done.
To do this you must understand the 4 legs of the relay and very basic wireing skills.
MegaMax
  • Suspension:
    Ground Control CoilOvers, $tillen FSTB, RSTB, Addco RSB
  • Lighting:
    Clear Signals, ALL bulbs Hyper White, Rewired Signals, Brighter Corner Light Mod, Rewired Fog lights, Blue Neon Headlights, Hyper White Washer Nozzles, Blue Under Car Neon, Blue Neon Under Dash, Custom wired Tail Lights
  • Cosmetic:
    Blue Break Calipers, ALL Windows Fully Tinted, NisMO badge on rear
  • Performance:
    TB Coolant Bypass, Cattman Jet-Hot Y-Pipe, High Flow Cat, Greddy Catback, $tillen HAI, Unothodox Racing Underdrive Pulley
  • Other:
    Optima Battery Relocated to Trunk,NGK Platinum Plugs, Synthetic Motor Oil (Every 5K), Synthetic Trans Fluid, 93 Octane Fuel ONLY.
  • Best E/T:
    15.4 with just the $tillen HAI 2 years ago… Now, go to the Track to find out..!
Dre's Corner
www.Maxima.Org
www.superstallions.com
www.f150online.com
Old 03-14-2004, 04:26 PM
Thanks for the info Max. This won't be a problem as I did something similar on my 04 F-350. Ford used the ground from the High Beam indicator to turn off the fog lights when the high beams came on.
