Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 03-06-2004, 09:57 PM
marija marija is offline
CD player problems
My cd player reeds NO MAGAZINE or CD ERROR when I try to play a CD. I have a 2000 Jetta Vr6 with moonsoon system. There is no cd changer connected. Can someone please help to figure out how to fix the problem??
Old 03-07-2004, 02:03 PM
boschmann boschmann is offline
Re: CD player problems
Was there a remote CD changer at some time? The radio has to be coded with a scan tool to look for a CD changer if one was installed. It is a little confusing why a radio w/internal CD would look for a remote changer magazine as I don't believe that was an option. Either way you will probably need to go to VW or find someone with a VAG-COM simulator to check out the radio's programming.
Old 03-07-2004, 09:19 PM
cd player
I bought the car used and will admit i do not know much about the radio system. There is the option to toggle between cd player and cd changer but I don't think there is a cd changer in the car. I have never used it. The light shows cd player but still says either check magazine or no magazine or cd error. It used to work fine until one day it stopped.
Old 03-08-2004, 04:30 PM
CD changer would be in the trunk. If it doesn't have one keep it toggled to CD player. Since you've probably already done that I'd say there's an internal problem w/the unit. I've head of this problem a few times, but never heard of a fix. It's probably worth a trip to the dealer to have them scan it.
Old 03-24-2004, 06:57 PM
tim_rose tim_rose is offline
Same Problem
I had the exact same thing happen last week to my 2000 Jetta w/ Monsoon system. I don't have a changer either and it keeps kicking out my discs, do you know how to reset the stereo without taking it to the dealer?
Old 03-31-2004, 05:46 PM
jeff1128 jeff1128 is offline
Send a message via AIM to jeff1128
I have to jump on the bandwagon too. I have a 2001 Jetta VR6 with the same Monsoon CD player as described above. I am the original owner and it has never had a cd changer.
I hope someone can solve this problem with the error message. I get the same thing, when you insert a disk, it says "CK Magazine" then "CD1 CD Error"
As for the dealer, they just want to replace the radio or have you go and get a new aftermarket. Either is a big bucks solution to what seems to be a simplier problem.
Thanks for the help!
Old 04-01-2004, 03:40 PM
You can try disconnecting the car's battery to reset the radio. Be careful though, on some models (mainly VR6's) you have to make the ECM relearn it throttle valve positions using a VAG scanner. Also make sure you have the radio SAFE code, depending on model it may or may not ask for it since it's still in the same car. An alternative would be to pull both radio fuses, but one of the fuses can be hard to find).
Old 04-01-2004, 03:43 PM
You can try disconnecting the car's battery to reset the radio. Be careful though, on some models (mainly VR6's) you would then have to make the ECM relearn the throttle valve positions using a VAG scanner. Also make sure you have the radio SAFE code, depending on model the radio may or may not ask for it since it's still in the same car. An alternative would be to pull both radio fuses, but the power at all times fuse can be hard to find.
Old 04-14-2004, 01:01 AM
Boschman, that was the first thing i thought of as well and did this. The Cd player worked for a week and then the same message came back up. Unplugged battery again and we'll see how long this lasts. Am I not letting it uncharge long enough (3 hours)? It remembers my presets, so wondering. Also, maybe I can unplug ECM?? Thanks for your help
Old 04-14-2004, 05:15 PM
tim rose, I assume your's isn't a VR6 as you didn't have problems with restarting. The radio will remember presets & the ECM will remember the radio even when disconnectd (that's why it dosen't go to safe mode). Be carefull with disconnecting the battery too much as it can cause strange things to happen. Lots of people get this error, when read with a scanner the code usually comes out CD inserted upside down. I have not seen a true fix for it, although some have suggested cleaning the laser optics.
Old 04-15-2004, 02:27 AM
hey Boschmann,
Works ok for now, don't want to have to pay dealer $100 to reset the thing, seems like should be an easier fix. Do you think we should all get aftermarket stereos? If the dealer can't fix it, not sure what the next step is here. suggestions? Thanks Bosch
Old 04-15-2004, 04:56 PM
I would try something like these:
http://www.amazon.com/exec/obidos/tg...66314?v=glance
http://www.bestbuy.com/site/olspage....&ref=03&loc=01
