Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-06-2004, 08:32 PM
charlesnj01 charlesnj01 is offline
Send a message via AIM to charlesnj01
what level turbo
looking to redo my 1997 integra engine over so lookingto add turbo what level of turbos are there?
Old 03-07-2004, 05:17 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
level of turbos?????? What does that mean?
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 03-07-2004, 09:51 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: what level turbo
i think he means like stages i.e. the stages on the rev hard kits.. either that or he's been playing too much need for speed underground
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 03-07-2004, 10:16 PM
99IntegraGSR 99IntegraGSR is offline
I'm looking into a t3/t4 hybrid turbo for my integra. Buy a smaller turbo if you want a quick spool up time, or buy a bigger turbo if you want maximum hp. Larger turbos will have more turbo lag.
Old 03-07-2004, 10:21 PM
DeleriousZ's Avatar
not necissarily.... in theory a larger turbo has more lag time because they take more exhaust force to get spinning up to speed, and unless you're in some sort of race situation, this generally can't be done by the good ol'e 4 bangers in our integra's. however... lag can be greatly reduced by using different methods of construction on the turbo... eg/ ceramic blades(generally very expensive) or ball bearings instead of floating liquid bearings. ball bearing is definitely the way to go if you have the money, because they can be quite a bit more expensive than the normal turbo's... hope i've helped ya a bit
Old 03-07-2004, 10:39 PM
lookingto get max hp out of my car
Old 03-07-2004, 10:44 PM
DeleriousZ's Avatar
max hp out of your stock engine?
Old 03-08-2004, 12:03 AM
no swap with custom
Old 03-08-2004, 12:06 AM
DeleriousZ's Avatar
i hope you got a fair chunk o change to spend on this.. cause engine swaps are nothing cheap..
are you looking for race or street? cause 300 whp is about a good max for an integra for street.. anything over that is just overkill
Old 03-08-2004, 08:19 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
get a turbo with about a .63a/r that will be good enuff of a motor with 1.6-1.8l and should flow aobut 300lb/min thats good for 300hp which you wont see on a stock botom end tegra.. and you will get fast spool up.. dont boost over 10psi and make sure you do your fuel managment..
1
Shift_BOOST
97 s14
Old 03-08-2004, 09:49 PM
doing the car for show but wanna make it fast too at the sametime
Old 03-08-2004, 09:54 PM
u know site to get turbo and engine at wanna get spoon or type-r engine
Old 03-08-2004, 10:59 PM
DeleriousZ's Avatar
well, www.totaljdm.com is good for engines... i'm sure there's tons out there, just search b18 c jdm in google... same thing goes for turbo's....
a little research goes a long way
Old 03-08-2004, 11:02 PM
b18 c come used? or is there new ones out there?
Old 03-08-2004, 11:04 PM
DeleriousZ's Avatar
it'd be a real hard time finding new engines for the b18 c... but talk to TEAM KLR... he said he was getting some brand spaking new engines... he might have a new b18 c for ya
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
