Old 03-06-2004, 07:41 PM
twost twost is offline
How do you remove Tension Pulley
How does one remove the TENSION PULLEY. This is the small pulley that sits between the power steering pump and AC compressor? This is on a 98 Eclipse 2.0 DOHC.
Old 03-06-2004, 09:46 PM
doc13ryde doc13ryde is offline
Send a message via AIM to doc13ryde Send a message via Yahoo to doc13ryde
Re: Remove Tension Pulley
Why are u removing it? There is a bolt on it and u unscrew it and pull it off but u need it to keep the belt tight
Old 03-06-2004, 11:14 PM
Am removing pulley because the bearing is shot. Easy enough to get the hex nut off the pulley bolt. Problem is that there is not enough room between the pulley and the sheet metal of the fenderwell to withdraw the bolt and remove it.
