Old 03-06-2004, 05:24 PM
Jay! Jay! is offline
Horizontally Opposed
Can't Access Second HD
Hi all...
My home PC crapped out, so I had to get a new computer. I bought everything I needed and assembled it myself using some new parts plus what was savagable from my old one. I was counting on using my old 7G HD in there, even if it's only to get back my old files, but I can't get XP to recognize it.
The BIOS can see both HDs. The new one as the master, the old one as the slave. If I set the CMOS to boot from the old HD, it loads to the desktop, then I can't do anything, because the machine doesn't recognize my USB keyboard and mouse.
XP shows only the new one as "c:". The XP Device Manager lists the other HD as installed, and can read the specs (size, etc.) but it just won't show it as a valid drive.
I've set the jumpers on both HDs to about every combination with no luck...
What to do next? Is my old HD just dead?
Hierarchy of Subaru:
(Click to see mine!)
Old 03-06-2004, 05:30 PM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
Hmmm sounds like a toughy...one thing I know with some manufacturer's that they will help you out if you try to get info from an older computer so you could try and call them...and anything you could ever think of for computer trouble with windows is here
support.microsoft.com
I hope this kinda helped.
Old 03-06-2004, 06:14 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Can't Access Second HD
Have you tried just booting from your old HDD? with out the new one installed?
If you had a USB moust and keybourd before then nothing should change.
Its possible its only a little screwed, and that should tell you for sure.
XP from my experiance is really good at recognising mroe than one drive, Iv had several in and out of my machine backing up other ppls stuff for freash installs.
Old 03-06-2004, 07:53 PM
I'm gonna borrow a ps/2 mouse tonight and try to boot on the old HD just to see if i can dump my files onto the new one...
the OS on the old one is Win ME. i forgot to mention that, piece of crap that it is...
Thanks for the help...
Old 03-06-2004, 08:01 PM
Good call; I found this:
Hard Disk Does Not Appear in My Computer or in Windows Explorer
(330140) - When you try to upgrade to Windows XP, or when you try to install a hard disk on your Windows XP computer, the hard disk may not appear in Windows Explorer or in My Computer, even if the hard disk does appear in Device Manager and in Disk Management...
My old computer has that GoBack bundle-packed on it.
Hope this works!
Old 04-22-2004, 06:56 AM
-Davo's Avatar
-Davo -Davo is offline
Banned
does it work yet?
I know how to get XP to get a slave drive to be reconized if you still need a bit of help.
Old 04-22-2004, 09:47 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Did you go into the aministrative tools (from the control panel) / computer managment / storage / disk management?
If you see it there, it probably has a partition that the computer can't read. While it will destroy the files on it, you could create a new partition and then you'll see the drive in explorer.
Resistance Is Futile (If < 1ohm)
Old 04-22-2004, 08:54 PM
Re: Re: Can't Access Second HD
Yeah, I had this "GoBack" program on the old HD which altered the master boot record. I had to boot of the old HD and disable it, and now it works fine.
Hope this works!
Old 04-23-2004, 10:40 AM
Shrocat Shrocat is offline
I suggest that you go back into bios and check to see if the proper type of drive is selected, Typically you can choose between Auto LBA or large. Every once in a while something will happen to my bios, and I have to go back in and change that and then XP will see the drive.
