| Off-Topic Talk about anything other than cars. |
I Need Help!!!! Answers Plz
Ok i have a 95 tsi awd was working fine lastnight i just went out to use my car for the 1st time today and when i start the car all the dash lights dont go out the low coolant, battery, brake light stay on everything else goes out and i also noticed when i was just running it down the road my temp gauge is running alot higher than normal but the car runs fine. Also with the key in the accessory position my stereo works fine and also in the run psition but when you start the car the amp will no longer work it it sounds like i get i noise in the sub when i push my brake pedal down. Do you think i have a bad ground? if so where? and how could this happen just over night. I ran the car for about 30 miles and the car run fine just the lights on amp messing up and my temp gauge running alot higher than normal.
PLZ HELP ME SOMEONE Eric |
Re: I Need Help!!!! Answers Plz
i also forgot to mention that i went threw some surious water yestarday you think some wiring got wet and is shorting out?
I just drove my car tonight, not sure if im crazy but also my dash lights seem alot brighter, my wipers look like they are going mach 2 along with the back wiper and my sprayers look like a fuckin pressure washer. Never had a import before if you pull the positive terminal off like a chevy or ford will it act the same? will the car stay running? to tell about the altinator?
Ok update i believe its a ground issue cuz i ran a direct wire from battery to amp which is grounded to chasy and the amp worked fine, now i wiggled some ground wires that go from battery to chasy and it seems to work better but only issue i see now is that all the lights still stay on until i get up to about 4,500 rpms and they finally go out.
Still ground issue? Car still runs like a top |
