Old 03-06-2004, 12:53 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
std and dx questions
I've been wondering what makes the dx's runs a little faster than the std since the have the same motor (d15b1/2). So what do you guys say? If I upgraded my std ecu with dx ecu, will there be any power increase or would it feel the same? And would the 4spd slow down the dx ecu from pumping 92hp. Or how about upgrading the 4spd to a 5spd, would I feel any difference? I've been wanting a little more power, especially around town since these std's can't keep up very well in city traffic. I just want some power without really tinkering around with the engine. Any suggestions would be bery helpful!
Old 03-06-2004, 12:56 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: std and dx questions
DX ecu cam MPFI from a SI also a 5spd would help. Also aftermarket intake helps alot for STDs
Old 03-06-2004, 01:32 PM
Bilson8tor's Avatar
Bilson8tor Bilson8tor is offline
Send a message via AIM to Bilson8tor
the 5spd tranny help, cuz u would have a higher final drive for the highway, and the final drive is slightly more aggressive compared to the STD
91 Civic CX - Sold
94 Accord EX - Sold
94 Integra LS - Cleaning it up
Old 03-06-2004, 01:52 PM
Shaguar47's Avatar
I'm pretty much aware that the si trans and the dx trans have different final gears, but I guess now what I'm asking is whether or not the std ecu is any different from the Dx ecu. If it would give me a little more power, then it'd be a simple plug and play item. But I'm wondering what you guys would say about it. And would there be any difference between the throttle bodys of both cars and if so, could you change any of it?
Old 03-06-2004, 02:19 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
the throttle body is different on the two engines. the spacer plate under the throttle body is different too, the STD one is more restrictive, and the TB doesnt open as much either. change that out if you want to get a bit more power.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-06-2004, 06:55 PM
Shaguar47's Avatar
Wow, now that makes a difference. Seems like putting MPFI on it would be easier than taking all the DPFI apart and changing everything to DX standards. Thanks for the info. Oh.....and by the way, has anyone done this before, changing an STD base throttle body to an DX throttle body?
Old 03-06-2004, 10:06 PM
EF You's Avatar
EF Life Giver
i have. its simple bolt on
