Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-05-2004, 11:19 PM
98-ls 98-ls is offline
abs light
about 3 months ago my abs light would come on after about 10 min. of driving and it would turn of and on. then a few weeks later it would turn on after i got over 15 mph. now it turns on when i start the car and doesnt turn off. does anyone know what this is and how to fix it.
Old 03-06-2004, 02:38 AM
riceroni's Avatar
riceroni riceroni is offline
Send a message via MSN to riceroni
Re: abs light
that happens to me too. since i got the car in november, it just goes on after i begin to drive the car and doesn't go off until i turn off the car.
i would like to know as well. the explanation in the manual kinda sucked.
Old 11-19-2004, 01:34 AM
EF_CaSe EF_CaSe is offline
Send a message via AIM to EF_CaSe Send a message via Yahoo to EF_CaSe
Re: abs light
im having the same problem.. i was changing the tie end rod and noticed the brakes are locked a little.. i could spin the hub with my hand but not as ez as it should be..
[]D [] []V[] []D ........ []D [] []V[] []D
Old 11-19-2004, 01:44 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: abs light
maybe theres some crap stuck on the ABS sensor at one or more wheels. take off each wheel and inspect it, no visible damage to teh sensor? nothing obstructing it? is the fluid in the ABS unit full?
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 11-25-2004, 12:28 AM
HontegraGSI HontegraGSI is offline
happens to me too. just bugs the hell out of me! what really causes this? mechanic said its common and it's no big issue. hopefully he's right.
Old 11-25-2004, 07:22 PM
94tegRS's Avatar
Re: abs light
well the light coming on isnt common and no big deal, it means somethings wrong with the ABS system and if you ever need to depend on it it probably isnt going to work.
current
history:
Old 11-25-2004, 07:56 PM
rushb18 rushb18 is offline
Re: abs light
Um in the abs unit thing you have to put brake fluid in it that shoul solve the problem.If you get that annoying sound when you start your car that would be your problem..
Old 11-29-2004, 12:36 AM
Checked brake fluid its full. what next? ya think it could be from my axles? the rubber on my axle is ripped on one side and all this oil coming out. yea i should replace it, but does that have anything to do with abs?
Old 11-29-2004, 12:47 PM
94tegRS's Avatar
Re: abs light
if the greas from the bot flies out anid gets all over the ABS sensor then I could see how that would cause the light to come on.
current
history:
