Old 03-05-2004, 10:58 PM
champion69 champion69 is offline
Hard to start
I cant get my truck (93 Votec CPI VIN W) to start unless I take a little bit of gas and dump it down the throttle body, then she immediately starts in an instant. Once started it runs very smooth with out a problem. I 've replaced plugs, plug wires, coil, cap, ignition module and rotor. Ive replaced the CPI spider. Still no change. The Fuel pressure with ignition on and engine off is 60psi. With engine started fuel pressure is 52psi. The fuel pump is about 6 months old. Everytime I turn the vehicle off I must give her a small sip of gas in order to start her.
Can someone out there suggest anything.
Thanks
Old 03-06-2004, 11:45 PM
hydropkd's Avatar
hydropkd hydropkd is offline
Re: Hard to start
change fuel filter,might be vapor lock in the gas lines if that doesnt work go to valvoline express lube ask for 3 part fuel system cleaner(not from auto parts store)runs around 39 dollars.
Old 03-07-2004, 04:29 AM
cobra1 cobra1 is offline
is your SES light on? if not, does it work?
the computer monitors the coolant temp sensor (CTS), intake air temp sensor (IAT), throttle position sensor (TPS), and manifold absolute pressure sensor (MAP) in order to determine the proper air/fuel ratio for starting.
it sounds as though maybe one or a combination of these may be out of range enough that the truck is trying to start too lean.
using a repair manual and an ohm meter you can check most, if not all of those sensors.
i'd lean more towards the IAT, MAP, and the CTS.
Old 03-07-2004, 01:43 PM
michelq michelq is offline
Re: Hard to start
check to see if fuel pump relay working to prime the system.
maybe coolent sensor reading too high
