Old 03-05-2004, 10:19 PM
revsev revsev is offline
Angry Squeaking Noise in dashboard
A squeaking noise which I feel has to be coming from inside my dashboard is driving me crazy. The noise occurs only when the vehicle is in motion and oddly enough, I think it only occurs under milder temperatures because is was not a problem all winter, but it is rearing its ugly head again since the fall. I took it in last spring. They said they took the dash apart and added some insulation in an area and that it was fixed. It's not. And it's very annoying. Any ideas?
Old 04-05-2004, 05:06 PM
MBurke MBurke is offline
Unhappy
I've got the same problem with mine. I just bought the truck a month ago and it just now got warm enough here for it to start I guess. I was just about to take it to the dealer when I saw you had posted this. Thought I would check if you have had any success with yours first?
Old 04-07-2004, 09:11 AM
Re: Squeaking Noise in dashboard
MBurke,
After taking it in for a second time, it appears that the problem has been fixed. This is what the invoice says: R&R upper trim panel and insulated contact areas. Road tested again with shop foreman to verify correction. Hopefully this fix will last. I do know that they also tried making an adjustment to the emergency brake cabel but when they tested it they still heard the noise. You'll have to let me know if they do the same thing or if it's a different problem.
revsev
