Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-05-2004, 07:32 PM
jimofcal jimofcal is offline
Transfer Case - Click/Click
my 1995 grand cherokee has a good bit of play when you rock the drive shaft back and forth - you can also hear a metalic clicking sound.
When rolling @ 10-12 mph @ about 1100 rpm you can really hear it "tick, tick, tick....is this a bearing going out?
Something I may be able to fix? Will dropping the front drive shaft until I can afford to fix be okay?
THANK YOU!!!
Jim
Old 07-02-2004, 12:53 PM
jssking jssking is offline
fluid
try checking the fluid level in the transfer case. I am going through the same problem. I jacked the front and spun the front tire and finally found the noise in the transfer case. You need to run 4 wheel drive about once a month and keep the fluid level moving. The noise baffled three mechanics before i found it. the noise was unbearable on the freeways and against sound walls. i just put fluid in last night and it now has a softer click. i KNOW i didnt put enough fluid in....so i'll be doing that this evening....
