Old 03-05-2004, 04:59 PM
bishopduke bishopduke is offline
99 Escort, Where is the firewall?
deleted
Old 03-07-2004, 01:30 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 99 Escort, Where is the firewall?
sounds like you don't know what a firewall is. it's the "wall in the back of the engine compartment that all the pedals and stuff mount to. get a rubber gromet kit, drill a hole in the wall and plug it with the grommet and run the wire through the grommet. sometimes you can jam a wire through existing grommets such as the one for the throttle cable.
Old 04-09-2004, 11:52 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
I've run into the same problem BishopDuke...on the passenger side is a rubber grommet, bout 2-3 inches in diameter. It is there for some wire to go through. Your not going to get it THROUGH the grommet, but better beside the grommet. Push it aside a little, and squeeze your cable through right next to it. I did it with 6 guage cable, it can be done. Easiest way to find it the first time is to look from the inside of the car towards the engine, you have to pull the carpet back a little bit, but it is there.
