Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-05-2004, 03:16 PM
todka todka is offline
Loud wind noise (2001 Aurora)
driving on the highway today (happened to be fairly windy today also) i heard an incredible wind noise. At different times it sounded as if it might be coming from under the grill area, then the roof area, and then the back end. I haven't heard this before and it lasted for a while, i wonder if I chalk it up to the windy conditions?
Old 03-05-2004, 11:39 PM
jessb45 jessb45 is offline
Re: Loud wind noise (2001 Aurora)
Did you check to see if any spash gaurds came loose. They might look ok when you are stopped but look for anything that could get caught by high winds. The underside of the aurora is nothing but spash gaurds.
Old 03-06-2004, 05:07 AM
RobertHammen RobertHammen is offline
Do you have a moonroof? Mine is a little uneven (thank you GM engineers and/or UAW build quality) and I hear quite a roar on windy days if the wind is blowing from the passenger side of the car (but not the other way around)...
Old 03-08-2004, 03:03 AM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Re: Loud wind noise (2001 Aurora)
As for the sunroof, clean the rubber weatherstrip regularly with silicone spray onto terrycloth and wipe. You can reach 99% of it using the tilt-up mode. It helps it seal so much better, without sticking!
Quality isn't expensive, it's priceless.
Old 03-08-2004, 08:27 AM
Thanks, i don't have a moon roof but I will check for loose splash guards.
Old 03-08-2004, 09:30 PM
dred98's Avatar
dred98 dred98 is offline
What's the difference between a moonroof and a sunroof anyway - are the terms interchangeable ?
Old 03-09-2004, 01:06 PM
Indy8's Avatar
Same thing to me.
Old 03-09-2004, 02:32 PM
mikelebo99 mikelebo99 is offline
Once upon a time there was a difference between the two. A moon roof was essentially a sunroof but did not slide back, it only popped open in the front to tilt up. This sounds like a Jeapordy question.
Old 03-10-2004, 12:11 PM
dred98's Avatar
thanks - now I know . . . . . .
Old 03-12-2004, 09:01 PM
dsatt12 dsatt12 is offline
Though they are more or less interchangeable to me now, I always thought of a sunroof as tinted glass like everything now. I had a buddy that had a VW microbus with a moonroof (striaght out of the owners manual) that was a huge section of opaque roofing material that slid back to open up.
Old 10-12-2004, 10:45 AM
jjbohning jjbohning is offline
I have the same noise. I only hear it when it is windy. It sounds like I have a ghost in my trunk.
