Old 03-05-2004, 02:41 PM
Toylet Toylet is offline
compression?
hey all~
i have a 1980 350 engine from a truck, and believe it's compressions is 8.5:1...and runs beautifully...I have a set of 1967 283 heads in the garage that are in pretty good shape...will installing those heads help me edge a few more ponies out of the 350? The 283 had a compression ratio of 9.25:1...pumping out 50 more horsepower than what i have now (145 vs 195)...am I having a pipe dream...any input is graciously appreciated.
Toylet
Old 03-05-2004, 07:39 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: compression?
port them out and throw in a cam. should wake up the truck a bit. i'd also get a edelbrock intake and k&n filter. if you have a decent Q-jet carb without too much emissions crap i'd keep it most people don't know a q-jet will flow 750CFM you should be able to get all this stuff for about $350. i assume you have 72cc heads now and the 289's are 64cc should make a difference any boost in compression makes a big difference.
Old 03-06-2004, 04:09 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Re: compression?
Originally Posted by Toylet
hey all~
Toylet
well, post a casting number, but im betting that the 283 heads have small 172/1.3 or 1.5 valves, they dont have seats for non lead gas, they will likely raise compression to the 11:1 range on a 350
it would be better to find a set of mid/late 80's swirl port 350 heads if you are keeping the carb, or get a set of L31 vortecs
Old 03-08-2004, 11:47 AM
hhmm...the heads are at home, so i can't get a casting number...but valves are the 1.71 and the 1.5.
So i can't use those heads due to the valve seats being meant for leaded gas? is there any way around that..such as milling them?
thanks
toylet
Old 03-08-2004, 12:53 PM
Re: compression?
thanks
toylet
the valve seats can be replaced, and at the same time, opened up for larger valves - 1.7 is too small for a 350 revving over 4000, but given the cost of this and given that the chambers are likely so tiny it will raise compression past a point you can deal with - there exist many heads on the market new or used that will be cheaper, raise compression slightly and have better ports and larger valves.
