Old 03-05-2004, 12:24 PM
john_diy john_diy is offline
Angry '98 Accord - power door locks not working
Hi,
Since yesterday the power door locks on my '98 Accord LX (Sedan) are not working. I noticed that it happened after I started the car and it died on me. I tried it again but this time with my foot on accelerator and it started fine. I started driving and then noticed the locks weren't operational. They were fine before this episode.
- When I press the power door lock button on driver or passenger side nothing happens (usually it locks all four doors)
- Manaul locking is fine
- When I lock the car with key it doesn't lock all the door (it only locks the door I'm at - driver or passenger). This is supposed to lock all doors too.
I looked at the interior fuse box on Passenger side and the door locks fuse looks ok (#12). I also swapped it with passenger side power window fuse and the window still worked so I guess it's fine.
Any ideas on what I can look at next? I read the the actuator might be a problem (I don't know what it is but I'm willing to give it a shot). Looking at Honda Manual looks like there are multiple actuators (one per door I think) and it doesn't feel like everything would conk off together.
Any help is appreciated.
thanks,
John
Old 03-05-2004, 01:06 PM
Talking
I looked for other similar mails and also searched the web. Found something about resetting the multiplex system. I did the following and it worked!
Set Wiper Intermittent Control to medium, Put the key in, Turn to ON, OFF, ON. When I turned to ON I didn't start the car (just go to ON position in ignition). This fixed it:-)
What is the multiplex system and why did I have to reset it?
thanks.
Old 04-27-2004, 11:41 AM
bmyers75 bmyers75 is offline
Thanks!
This also solved my problem.
Thanks!
Old 04-18-2005, 10:42 PM
Peter_d16 Peter_d16 is offline
Power Door Locks - Passenger side - Not working
I've been having a problem with the power door locks on my 1999 Accord LX. Started with the rear passenger door lock --- now both the passenger side power door locks are not working.
Tried reseting the multi -- mentioned in the note above - to no eval...
A ford (I know) mechanic said it was probably faulty actuators -- But what are the odds two go bad so close together...
Any ideas... Is there a way to find a honda accord wiring diagram online?
Old 07-16-2014, 11:17 PM
bryan_az bryan_az is offline
Re: '98 Accord - power door locks not working
This fixed my issue! Thanks 10-year-old post!
