Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-04-2002, 10:54 PM
GuitarManiac101 GuitarManiac101 is offline
Send a message via AIM to GuitarManiac101
Lowering Springs
If I get a set of lowering springs that will drop my car 2 inches, will I need a suspension bushing kit? What are bushing kits? What else will I need other than the springs to lower my car? Anything?
Old 01-06-2002, 04:17 PM
layingrubber layingrubber is offline
For a 2 drop, you will need a camber kit, or you will go through tires really fast
In order to get a loan you must first prove you don't need it
Old 01-06-2002, 05:23 PM
jdmakkordman's Avatar
jdmakkordman jdmakkordman is offline
Send a message via AIM to jdmakkordman
unless your oem bushings are worn theres no need to replace them right away but lowered 2" you will need to replace them eventually...you'll need a camber kit shocks and an alignment...happy lowering
:bandit:
Old 01-07-2002, 07:20 PM
Type R Type R is offline
Post
What does a camber kit do? What are the bush things?
*Drifter To Be*
Old 01-07-2002, 07:28 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
basically a camber kit makes your car rool normally and not on the endge of the tires and bushings replace the rubber oem ones and make your ride better
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Springs Made in Canada springman West Canada 0 12-01-2010 03:14 PM
Lowering Spring HELP! sentoyang Brakes and Suspension 2 10-23-2009 04:34 PM
lowering springs and front/back springs?? ynii_g Camry/Camry Hybrid/Vista 4 05-30-2004 12:28 PM
Ground Control adjustable springs VS. lowering springs AznDragon Tires and Wheels 3 02-17-2002 05:21 PM
